Old 05-19-2003, 04:58 AM   #16
stormperson's Avatar
Send a message via AIM to stormperson
what kind of pipe do you have?
stormperson is offline   Reply With Quote
Old 05-19-2003, 05:31 AM   #17
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by bbntc3
hmmmm! Kinda missed the point there did'nt you?? Silicone Sealants and silicone fuel line? Hmm? maybe use fuel line for a gasket then.
you are saying silicon cannot hold up nitro fuel? right? it is the material i am talking about and i believe you are talking about the material.
Manticore is offline   Reply With Quote
Old 05-19-2003, 09:03 AM   #18
Taylor-Racing's Avatar
I use the Permatex Ultra Blue - only because I have it. The Ultra Copper works just as well and both of these are sensor safe varieties. Used sparingly on a clean surface I haven't had any trouble caused by fuel.
Avoid the older acetic acid based silicones - they work (well sort of) but that acid sure does eat into alloy.
Taylor-Racing is offline   Reply With Quote
Old 05-19-2003, 03:53 PM   #19
Send a message via AIM to AndrewtheRCman
im running the stock AE rear exhaust pipe
AndrewtheRCman is offline   Reply With Quote
Old 05-19-2003, 05:13 PM   #20
try running a .15 (big block) gasket. i run a RD logics pipe and i find that i leak with the stock .12 gasket, but with a .15 it secures it better and it seals snug. also try a new spring
engine sealant mcc Singapore R/C Racers 10 09-13-2007 10:10 PM
Carburetor sealant rccobra705 Onroad Nitro Engine Zone 7 03-14-2007 09:19 PM
Red RTV sealant to crankshaft mrgsr Onroad Nitro Engine Zone 1 12-11-2006 06:51 AM
please delete, answer found Valentin.H Electric Off-Road 0 06-29-2006 11:33 AM
Nova Rossi engine Air leak or fuel leak? Solara Nitro On-Road 15 01-21-2005 04:00 AM
