engine settings?
Hi everybody,
i would like to enquire about the default settings of a Novarossi -3 port turbo engine as my carb gets hot after a few rounds and cut off the supply of fuel to the engine.Help!..... The engine comes with a M-speed heat sink. Thanks:sweat: :sweat: :sweat: |
you need to run more fuel to you motor and what kind of fuel are using
Re: engine settings?
Originally posted by Isolate Hi everybody, i would like to enquire about the default settings of a Novarossi -3 port turbo engine as my carb gets hot after a few rounds and cut off the supply of fuel to the engine.Help!..... The engine comes with a M-speed heat sink. Thanks:sweat: :sweat: :sweat: |
T-shirt:is it a modified by m-speed or just a standard S3 reply: it's just a standard S3.... td-civ you need to run more fuel to you motor and what kind of fuel are using i'm using blue thunder....but once i add more fuel the engine tends to flood.... |
uhmmm get some Trinity Fuel.....
THeGame: uhmmm get some Trinity Fuel.....
THeGame: uhmmm get some Trinity Fuel..... i thought it was just the engine itself not tune properly or the carb's dirty... being recommended by my friends to just clean the carb as they suspect the carb's dirty . |
