Old 09-24-2007, 01:46 PM   #1
asw7576's Avatar
Default Long Body vs Short Body Glow Plugs ?
http://rc-mushroom.com/product_info....oducts_id=4521
or
http://rc-mushroom.com/product_info....oducts_id=4522
Long body for .21 engines while short body for .12 engines ??
Which type is better for humid, tropical and hot weather country ?
Thanks !
Old 09-24-2007, 02:11 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
I believe it is about the pinlength on the plug. A longer pin is a colder version compared to a plug with a shorter pin.
I see it as the short pin nr.7 is a 7 plug and the longer pin nr.7 is actual 7.5 in gradation
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-24-2007, 03:54 PM   #3
teamgp's Avatar
Take a look at this web page.
From what I've read, the deciding factor between either short or long plugs, is more centered around nitro % content and then humidity. Finally, you choose the plug number based on temperature.
However, this is a general rule of thumb as different motors with different modifications, may work better with a plug type that normally wouldn't be recommended.
One thing I've found is that if your motor won't idle for more than a few seconds, without running the low end too lean, then you should try a hotter plug (lower number).
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 09-24-2007, 07:09 PM   #4
afm
afm's Avatar
The numbers and characters on the plugs, are the product number, wire thickness, and thermal range of the plug’s body. Example: The Novarossi C6TG (F) or (C)
Product:C (Conical)
Wire Thickness: 6
Plug Type: T (Turbo)
Plated:G (Gold)
Thermal Range:F (Fredda = Cold) C (Calda = Hot)
The plugs with cold thermal range F (Fredda), have a body with thinner walls and shorter body, so they dissipate heat better and faster to the engine head.
The plugs with hot thermal range C (Calda), have a body with thicker walls and longer body, so they dissipate heat better and faster to the engine head. The number of threads is the same on both types of plugs.
How to select the proper plug:
•When the ambient temperature is high, we have to use a plug with thicker wire.
•With higher compression, we have to use a plug with thicker wire.
•Humidity determines if we use a Cold (F) thermal range, or Hot (C) thermal range.
•With high humidity percentage we should use a Hot (C) thermal range plug.
•If we have high temperature and high humidity, we should use a plug with thick wire and a Hot(C) thermal range.
The best instrument to determine which Turbo Plug to use, is those table digital weather stations, that have Temperature, Humidity, and some also Barometric Pressure on them. That is the key to success or failure tuning engines with Turbo Glow Plugs, because they are so sensitive to weather variations that is unbelievable.
AFM
afm is offline   Reply With Quote
Old 09-25-2007, 03:00 AM   #5
rcabj's Avatar
good write up AFM...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 09-25-2007, 03:56 AM   #6
asw7576's Avatar
Thank you AFM and everyone else.
I already order Novarossi short body C7TGF and OS P8 from RC mushroom.
LOL, I thought longer body has more coils inside
Old 09-25-2007, 07:51 AM   #7
teamgp's Avatar
For high humidity, you should be running the C7TC not the F.
Guy Hood
Old 09-25-2007, 12:33 PM   #8
asw7576's Avatar
Arrghh...... perhaps you are right,
I thought F (Freda) means Cold, so implicitly, it has thicker wire / coils inside.
WTB:Stadium Truck body,plugs,ect Snipesr82 R/C Items: Wanted to Buy 0 03-24-2007 11:10 PM
Nitro accessories needed: Glow Plugs, Glow Ignitor, Temp Gun Cain R/C Items: Wanted to Buy 8 07-05-2006 06:22 PM
Long body clips tunnelhead Electric On-Road 18 02-24-2006 12:50 PM
2 glow starters and a body reamer t to the maxx2 R/C Items: For Sale/Trade 1 02-22-2006 04:41 PM
Will a standard glow ignitor work on a turbo glow plugs? Ducati998 Nitro On-Road 3 01-20-2003 12:54 AM
