Old 05-15-2003, 12:52 PM   #1
alucard13's Avatar
Default Fuel change
If i change from one brand of fuel to another, both using the same nitro percentage, is thier anything i should do to the engine?
alucard13 is offline   Reply With Quote
Old 05-15-2003, 01:12 PM   #2
Different fuels have different oil %, so you will have to retune the engine. Other then that it should not be a problem
nitro dipstick is offline   Reply With Quote
Old 05-15-2003, 01:45 PM   #3
alucard13's Avatar
i did notce that the new fuel that i want to use uses 18% oil and my other fuel only used 16%. With the higher oil content will it run hotter?
Old 05-15-2003, 02:01 PM   #4
Aeon Racer's Avatar
Send a message via AIM to Aeon Racer
Exactly the opposite. It should make the engine run a little cooler since it has a little more lubrication. Just retune the engine and you should be all set...
Aeon Racer is offline   Reply With Quote
Old 05-15-2003, 02:45 PM   #5
alucard13's Avatar
Awesome, thanx for the help.
Can you change from the fuel you started with? Captpete Rookie Zone 3 06-28-2008 02:40 PM
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 07:34 PM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 10:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 05:44 PM
Should I change fuel? solosigmun Singapore R/C Racers 30 04-10-2003 10:29 PM
