Old 09-23-2007, 05:27 AM   #1
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default RED DOT glow plug?
HI Guys can anyone suggest a good glow plug fror my JL red dot? I live in warm enviroment?also does this engine use a shim under the glow plug?
thanks
aussies1129 is offline   Reply With Quote
Old 09-23-2007, 06:58 AM   #2
s10dude's Avatar
the guy's here (warm spot ) use 6's.... they use 7's if they go to 30% fuel (in the US ).. make sure you use Picco plug's as othere don't seal correctly and cause leaning out and motor failure..( have see this )...but i would say to use a Picco 6 for turbo....
you don't need to add a shim....i'm not sure about removing any....are you usuing 16% fuel ?
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 09-23-2007, 07:09 AM   #3
hey dude yes I can only use 16% here in australia humidity is around 70-80% and more in summer also wheres the best online shop to get picco/ofna plugs?
Old 09-23-2007, 07:10 AM   #4
I was reading throught the jl.12 thread and in there it said for 16% remove one shim,for 20-25% leave alone,for 30% add one shim.
thanks
Old 09-23-2007, 07:11 AM   #5
are you running a red dot in a g4s?if so how is it running and what pipe are you using?have you got ed trans in your car?
cheers
Old 09-23-2007, 07:57 AM   #6
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Hi Michael, the IDM i run is very similar to the red dot. both engines are picco based and i use the ninja 6 plugs. as for the shims, i tried one removed for 16% recomendation and then refitted it. the top end is a bit better with both shims fitted. yu can gain a bit more bottom end with one shim removed. as for the pipe i used the IDM 2607 pipe, with great results. with gearing, the std ED trans gearing is fine for the engine and pipe combo. if you need a bit more low end then put on a 52t 1st spur. but i generally leave the 46t 2nd spur on all the time.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 09-23-2007, 09:27 AM   #7
hi Paul thanks mate I just ran the first tank thru it tonight and man it was vey tight at tdc it seized there afew times, I put some after run down there to lube it up took out the glow plug and ran it on the box to free it up then left the glow plug starter on for a while cause I have not heat gun and she fired up and ran consistantly, got through half a tank stoped then another half and she was max at 45c very rich! oh and I removed one head shim and am using a picco p6 medium plug will see how it goes.
thanks mate!
Old 09-24-2007, 06:47 AM   #8
s10dude's Avatar
this is good info....and no i use a TZ 3P...but there are G4S at my track that use the JLR RED DOT and they are FAST!....it's a great motor and i plan to buy one to have in my arsenal of extra's...
Old 10-06-2007, 11:11 PM   #9
Team Kamikaze's Avatar
thanks
A PICCO P6TH or a P6TC will work.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
WHAT GLOW PLUG SHOULD I PUT IN IT............. kyosho 444 Onroad Nitro Engine Zone 1 04-14-2007 11:35 PM
glow plug help timmy187 Monster Trucks 3 04-19-2006 08:56 PM
GLOW PLUG FOR RB S5 HELLOkitty Electric Off-Road 4 10-24-2005 10:46 AM
RB S7 Glow Plug? RCWannabe Onroad Nitro Engine Zone 1 03-23-2005 09:09 PM
Glow Plug. tkhoo Nitro On-Road 7 07-14-2003 08:26 PM
