Old 05-14-2003, 03:47 PM   #1
TRF_TG10R's Avatar
Default Cx-12 carb
If you have Novarossi cx-12 can you plz post your carb setting..
thanx
TRF_TG10R is offline   Reply With Quote
Old 05-15-2003, 11:23 AM   #2
Send a message via AIM to Johnnytc3
Default w
w
Johnnytc3 is offline   Reply With Quote
Old 05-15-2003, 12:11 PM   #3
A good starting point for me has always been 4 out on top and 2 out on low. Adjust the response from there by closing the low 1/16 to 1/4 turn at a time.
sook is offline   Reply With Quote
Old 05-15-2003, 01:15 PM   #4
I have the same engine. According to the instructions, the starting settings should be 4 turns out on the main needle, and 3 1/2 turns in from flush on the low speed.
nitro dipstick is offline   Reply With Quote
Old 05-15-2003, 01:18 PM   #5
is that the number of turns from the tightest or leanest position?
Old 05-15-2003, 01:29 PM   #6
Yes.
Old 05-15-2003, 01:35 PM   #7
On the high speed, turn the needle cw until it stops, then turn it ccw 4 turns. On the low speed, Nova Rossi suggests turning the needle CCW until it is flush with the nut on the carb, then turning CW 3 1/2 turn. This is to prevent damage to the needle.
Old 05-15-2003, 01:37 PM   #8
man im retarded theres three screwdriver settings which one is which sorry i bought a used one and dont have a manual
Old 05-15-2003, 01:42 PM   #9
High end needle is the one on top. Idle screw is usually small black screw located near the brass screw. Do not touch the brass screw. Low end needle is the one inside the slide.
Converting Rotary Carb to Slide Carb? hrnts69 Nitro Off-Road 1 07-18-2008 12:29 PM
WTB 11L ROTARY CARB FOR .18TZ, HAVE NEW SLIDE CARB TO TRADE? SHAGGS R/C Items: Wanted to Buy 0 12-01-2006 03:34 PM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Onroad Nitro Engine Zone 10 09-25-2004 09:29 AM
6 or 6.5mm carb xtreme888 Onroad Nitro Engine Zone 2 09-19-2004 07:41 AM
Sirio .12 with Novarossie Carb -CX12 carb fit? au_Nightmare Nitro On-Road 5 12-15-2003 03:24 PM
