Old 09-20-2007, 11:37 AM   #1
Loveless's Avatar
Default Hudy automatic tire truer blade.
Yo fellas i have a hudy tire truer, my blades dull and i want the the carbide blade but cant find one, i was told that i can use an alternate blade made from a hacksaw blade if this is true which blade to use. All help is appreciated thanks...
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 09-20-2007, 11:46 AM   #2
JayL's Avatar
this is true, seen it work pretty well, not quite hudy but good.
do a search, i know sorry
there was a big thread about a month ago all about it
JayL is offline   Reply With Quote
Old 09-20-2007, 12:19 PM   #3
lil-bump's Avatar
Trader Rating: 83 (100%+)
The Blade you want is a JIG saw blade not a hacksaw blade. Your looking for a 24 TPI Bosch or Porter and Cable blade. I would install two of them with the blade teeth opposing one another. This configuration gives an awsome cut. I believe just as good as a hudy. The single blade will leave lines in the tire.
hope this helps
lil-bump is offline   Reply With Quote
Old 09-20-2007, 01:17 PM   #4
Loveless's Avatar
Default Blade
I guess i would remove the old hudy blade and use it as a template to make the new blades correct or does it matter.?.
Old 09-20-2007, 01:35 PM   #5
I have a friend that cut the end off of a Mico tire file, and uses it in place of the cabide cutter. It works freaking awsome.
WARDO is offline   Reply With Quote
Old 09-20-2007, 01:38 PM   #6
Team Kamikaze's Avatar
I have the Hudy Carbide Cutter for Hudy tire truer in stock.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-20-2007, 01:41 PM   #7
lil-bump's Avatar
I would put the blades on and true a fresh tire to around 62mm based on the dial settings. Whatever its off by use a dremmel and grind the back side of the blades until its the correct depth. Now if you have a Hudy truer by all means just replace it with a Hudy blade. I have a Hudy blade but it takes my truer almost 2.5 mm out of calibration on a Ofna truer.
Old 09-20-2007, 02:23 PM   #8
wallyedmonds's Avatar
i like hacksaw blades
the ones with the most teeth per in
i dont like the hudy bit why you ask,it gets dull and its $50.00 what a waist of money.
to me anyways.
wallyedmonds is offline   Reply With Quote
Old 09-20-2007, 02:29 PM   #9
to me anyways.
You are wrong the Hudy carbide cutter will last 100 times or even 200 times over the hacksaw blade, at the end the Hudy carbide cutter will be cheaper.
Old 09-20-2007, 02:37 PM   #10
do you know how many hacksaw blades you can get for 20.00 buck's
i had a hudy bit and took it off and sold it to someone that wanted it.
and now they to just use hacksaw blades.
Old 09-20-2007, 02:42 PM   #11
The Hudy Carbide Cutter will outlast $100.00 worth of hacksaw blade, so if you are smart you do the math
Old 09-20-2007, 02:49 PM   #12
thats the thing,it dosent.
the cut really gets crappy or i should say not to my liking.
and its not just me thats saying this.
Old 09-20-2007, 02:54 PM   #13
How would you know? you don't even have one
Old 09-20-2007, 02:54 PM   #14
i said i had one and took it off
Old 09-20-2007, 03:12 PM   #15
Then you never knew how long it should last
Hudy Automatic Tire Truer Rock Racing R/C Items: Wanted to Buy 0 03-18-2008 06:13 PM
Hudy automatic tire truer Chino R/C Items: For Sale/Trade 12 02-10-2008 08:47 AM
OFNA automatic truer w/ Hudy arbor and blade Turbo Joe R/C Items: For Sale/Trade 5 11-19-2007 12:40 AM
HUDY Automatic Tire Truer Michal101 R/C Items: For Sale/Trade 8 07-05-2005 12:40 PM
Ofna fully automatic truer with Hudy carbide blade LIKE NEW! wannabee R/C Items: For Sale/Trade 5 05-05-2005 09:56 PM
