Old 09-22-2007, 05:07 PM   #46
wallyedmonds's Avatar
Originally Posted by Team Kamikaze View Post
That's why! you have an "Intgcy" truer which is an "INTEGY" knock off, then the "angel" needs to be an angle for it will work.
sorry i spelled it wrong
integy
and you cant rotate the arm.
wallyedmonds is offline   Reply With Quote
Old 09-22-2007, 05:22 PM   #47
Team Kamikaze's Avatar
integy
I have seen people installing Hudy carbide cutter on an Integy tire truer, and it cuts nice.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 09-22-2007, 05:25 PM   #48
im sure it dose
you just got to mod the bit a bit
file it so it fits in the slot.
Old 09-22-2007, 08:30 PM   #49
Taylorm's Avatar
Originally Posted by Scott Fisher View Post
Hudy needs to build a machine that will detect the very very very very very few posts that Walley makes that are actually worthwhile. It will need to be quite selective and intricate as he makes A LOT of posts and not many are worth the bandwidth.
AKA THE GNAT FROM TORONTO CANADA.........at least he has the gnat part correct...............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 09-22-2007, 09:16 PM   #50
Originally Posted by nigelnuggets View Post
The "intgcy" truer has almost the same "angel" as the Hudy Truer, although you are right about the modification to fit the blade, however the motor on the "intgcy" truer is slightly smaller therefore has less power than the Hudy truer. (Results: Not as clean as a cut) No Hudy truer ever has a "vertical" blade, it sits at about a 45 "angel".
Old 09-22-2007, 09:17 PM   #51
and that name was given to me by a guy in CA that tells ppl to buy stuff that dosent work on there car.
Old 09-22-2007, 09:29 PM   #52
Who is that guy?
Old 09-22-2007, 09:37 PM   #53
thats not important
and i just seen the hudy truers and they all seem to be on a 45 degree angle now.
wish i had one of those
Old 09-22-2007, 11:30 PM   #54
nigelnuggets's Avatar
Send a message via AIM to nigelnuggets
thats not important
Trippin...
Kamikaze Toys and Hobbies. www.kamikazetoysandhobbies.com / www.kamikazercracing.com
nigelnuggets is offline   Reply With Quote
Old 09-24-2007, 11:04 AM   #55
JayL's Avatar
lol, so Scott you will tell me to buy a mtx-4 because it is a better car? if yes, then I listen otherwise I stand by my statement.
Team drivers know lot's about the stuff they run and I can trust that info.....
but please don't tell me any team driver tells anyone another car is better than the one the are paid to run....
back to topic,
I'd be curious to see a close pic of a tire cut by both
JayL is offline   Reply With Quote
Old 09-24-2007, 04:29 PM   #56
back to topic,
well one he drives a RRR now and he is smart on setup and stuff
we just think different on some things sometimes i think of it as just fun.
just want to know what angle or degree dose every one cut there tires at for sedan and 1/8.
Old 09-24-2007, 04:31 PM   #57
Trippin...
the cost is to high but the way the Canadian $ is now (more than the us) it may be cheaper to get so hmmmmmmmmmmm maybe.
Old 09-24-2007, 04:59 PM   #58
Serpentd's Avatar
Dude, what do you mean by angle or degree? Are you refering to the angle that cones the tire to accomodate the camber your running on the car? If that's the case, then for 1:8th scale I use 0-.5 degrees for the front and 1 degree for the rear. For sedan I have only trued at 0 degrees. But might try a half of degree (.5) for the rear.
I'm no expert with this by any means, but it does help get your tires scrubbed to the proper camber angles (coneing). I find that when the rear tires are coning well, then your making good use of your tires contact patch with the track. You always want to have the tires cone with a smaller diameter towards the inside, if your tires (usually the front) start to cone the wrong direction then you need to add more camber. Make sence? Good luck man.
Blessed are the SIC
Serpentd is offline   Reply With Quote
Old 10-06-2007, 12:31 PM   #59
Loveless's Avatar
Default What milimeter?.
Yo guys can i set my truer to cut 2mm at a time now that i have the carbide bit with the sweep at its slowest point, or does it matter?.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 10-06-2007, 02:28 PM   #60
If your truer can cut 2mm at a time go for it, by the way what brand truer do you have?
Hudy Automatic Tire Truer Rock Racing R/C Items: Wanted to Buy 0 03-18-2008 06:13 PM
Hudy automatic tire truer Chino R/C Items: For Sale/Trade 12 02-10-2008 08:47 AM
OFNA automatic truer w/ Hudy arbor and blade Turbo Joe R/C Items: For Sale/Trade 5 11-19-2007 12:40 AM
HUDY Automatic Tire Truer Michal101 R/C Items: For Sale/Trade 8 07-05-2005 12:40 PM
Ofna fully automatic truer with Hudy carbide blade LIKE NEW! wannabee R/C Items: For Sale/Trade 5 05-05-2005 09:56 PM
