Old 05-14-2003, 02:30 PM   #1
alucard13's Avatar
Default motor problem?
I have the mugen MR12 and for some reason when i go full throttle down the road the engine starts to slow down and then die. Any one got any idea why? the temp is normal.
the motor seems fine. i start it back up and everything seems normal. only when i go full speed for more than a few seconds. the only thing i can think of is bubbles in the fuel line. i did put in a fuel filter the other day. and this is the first time i've gone full throttle like that since the fuel filter. could that be it?
alucard13 is offline   Reply With Quote
Old 05-14-2003, 02:49 PM   #2
If it seems like its starving at WOT, then its probably too lean on the HSN. Try richening it up alittle and see if it helps.
RandyT is offline   Reply With Quote
Old 05-14-2003, 06:12 PM   #3
rrgt_kid's Avatar
take the fuel filter off there not really good!
rrgt_kid is offline   Reply With Quote
Old 05-14-2003, 08:22 PM   #4
alucard13's Avatar
really? someone told me never to run it without one. i ran it several times without it and it didn't seem to hurt. tomorrow i will take it off and see what happens. thanx for the help
Old 05-14-2003, 09:10 PM   #5
VoneRkid's Avatar
My S1 JP did the same with the fuel filter. Just take it off
Damo
VoneRkid is offline   Reply With Quote
Old 05-15-2003, 12:09 AM   #6
THeGame's Avatar
Send a message via AIM to THeGame
take the fuel filter off and run Trinity 30% fuel worked for me.
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 05-15-2003, 12:18 AM   #7
Roger's Avatar
rip off the fuel filter. You should be fine
Roger is offline   Reply With Quote
Old 05-15-2003, 01:12 AM   #8
Im2lazy's Avatar
I still believe that I would still think about richening your high end needle settings.
If you have a properly designed fuel filter, it would not be the cause of this. There are filters that don't work properly, but that is relatively rare.
You have the sullivan filter (I think I remember), and it should not be causing a problem. However, if you take it off, have no problems, then it was poorly manufactured... but if you still have the problem, then you know the filter was not the problem, and I would suggest tha you put it back in, unless you have a fuel tank that has a built-in filter, then there is not much reason to have another filter.
Im2lazy is offline   Reply With Quote
Old 05-15-2003, 06:40 AM   #9
alucard13's Avatar
I am going to take the filter off today and see what happens. if it still happens i'll richen it up. i'll post the results later today.
Old 05-15-2003, 04:18 PM   #10
alucard13's Avatar
ok, i took the fuel filter off and it still happened. so what i did was let it warm up for a few minutes and richened it up just an 1/8 of a turn. doesnt seem to be any more problems
Old 05-16-2003, 09:30 AM   #11
td-civ's Avatar
Trader Rating: 18 (95%+)
richen it up a little more then it needs and it will never die on you at top end because i had the same prob with my car i run a filter and trinity 30% in my car all the time and never had a prob with it
td-civ is offline   Reply With Quote
Old 05-16-2003, 01:55 PM   #12
alucard13's Avatar
cool, thanx for the advice
Motor problem moorespeed Electric On-Road 6 09-09-2007 11:36 AM
Motor problem with B4 Jeff K. Electric Off-Road 10 07-31-2007 12:35 AM
I think I have a motor problem quakebo R/C Tech Site Forum 0 04-21-2007 08:17 AM
Motor problem?? OptimaMid89 Electric Off-Road 8 04-10-2004 01:02 AM
Motor problem plbman Electric On-Road 6 01-16-2004 10:45 PM
