Old 09-18-2007, 01:00 PM   #1
Loveless's Avatar
Default Quickest way to change out front belt.
Yo fellas i was wondering which is the fastest or quickest way to change out your front pulley belt when its gone bad?. with out tearing the whole front end apart, all help is appreciated thanks...
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 09-18-2007, 01:28 PM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
- Unscrew the frontscrews of the radioplate
- unscrew the screws the left bulhead at the underside
- unscrew the bodymount and shocktower (with shocks unscrewed of he suspension arms)
- unscrew the exhaust mount and push the exhaust upwards
- remove the left bulkhead
- remove the side pulley
- push in the middleshaft so you can pick the C-clip from the shaft at the servo side with a tool.
- remove the middle shaft
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 09-18-2007, 02:38 PM   #3
regardless, its gonna be alot of work. my best advise for you is too practice taking out the front belt at home rather than at the races. this way, you'll know EXACTLY what to do when it comes time for that belt change.
Also, it would be better using a electronic screw driver like the milwaukee brand. buy the ofna hex bits ( part number: ofna 93119 ) because they are compatable with the milwaukee driver.
Quickest way to change out front belt.-tool-bit-93119.jpg   Quickest way to change out front belt.-6539-6-lg.jpg
Paul D. is offline   Reply With Quote
Old 09-18-2007, 03:13 PM   #4
Loveless's Avatar
Default Screw driver
Whats the part number on that driver bro, and where can i pick one up thanks...
Old 09-18-2007, 04:57 PM   #5
Here you go:
http://www.milwaukeeconnect.com/weba..._192149_192137
There's a store locator on the website to find the nearest store near you.
Old 09-18-2007, 05:56 PM   #6
Trader Rating: 93 (100%+)
Default Screwdriver
Craftsman has a good one for 19.95. It's 3.6 volt and works great.
latemodel13 is offline   Reply With Quote
Old 09-19-2007, 08:19 AM   #7
almtx3's Avatar
Wish there was an easier way to swap out the front belt but for now you're gonna have to do some taking apart. Paul D.'s recommendation of using an electronic screwdriver is the best advice in my opinion.
I picked this one up at wallmart about a year ago. Not sure if they still have them but heres a link:
http://www.fadfusion.com/selection.p...er=30383000285
Its small and compact so it fits perfectly in my box and has plenty of power to take apart my car fast if needed. Price is good too...good luck!
almtx3 is offline   Reply With Quote
Old 09-19-2007, 08:50 PM   #8
Loveless's Avatar
Default Driver
Thanks a lot guys for the help, i went with the craftsman driver it came with a lot of bits including drill bits, once again thanks for all you guys help....
BEST WAY TO CHANGE FRONT BEARING buckeye34 Nitro Off-Road 3 04-30-2008 12:43 AM
gpx-4 on-road FRONT BELT(newbie Q) Dave_x8 Nitro On-Road 3 12-04-2007 12:56 AM
Front belt stripping ... Loveless Nitro On-Road 26 08-26-2007 05:11 PM
Front belt for Serpent 950R Yellowtaro R/C Items: Wanted to Buy 0 08-21-2006 11:39 AM
Overly Tight Front Belt DIMO Electric On-Road 5 07-14-2005 02:53 AM
