Old 05-13-2003, 10:58 PM   #1
chachi's Avatar
Default Reforming dented dual-chamber pipes?
I have heard that dented pipes can be reformed by filling them with water and putting them in the freezer. Can this be done with dual-chambered pipes? I need to reform my RD Logics pipe, and am afraid that freezing water in it may cause the chambers to lose their shape relative to each other. This, in turn, would cause the pipe to lose performance. Anybody tried this?
chachi is offline   Reply With Quote
Old 05-14-2003, 12:29 AM   #2
Send a message via Yahoo to speedy100
Default Re: Reforming dented dual-chamber pipes?
yes, it would work but my friend has experienced that the pipe had expanded too much and it was cracked from the welding point, especially the AE dual chamber pipe. to avoid that happened, you should put a retainer to maintain the pipe in right shape of diameter when expanding in the freezer. good luck and hope it would help.
speedy100 is offline   Reply With Quote
Old 05-14-2003, 01:26 AM   #3
rrgt_kid's Avatar
when freezing your pipes make sure that you have all the holes on the pipe blocked up very well otherwise the ice will just expand and wont pull the dent out of the pipe at all. Usually this procedure can take over night and even a couple of goes at it. To help stop the pipe from over expanding put a couple of zip ties rapped around the pipe to minimize that over expansion!!!!
Jeremy.
rrgt_kid is offline   Reply With Quote
Old 05-14-2003, 01:44 AM   #4
chachi's Avatar
What do you use to plug the holes?
Old 05-14-2003, 08:01 AM   #5
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
When I did the trick to my old HPI tuned pipe, I pluged the header and stinger with rubber Great Planes carb-caps. They come in a package of several sizes. I then stuffed a screw into a short piece of fuel tubing ( to plug it ), I think I CA'ed it the screw into the tubing also, then put that on the pressure nipple with a zip tie holding it down. I also zip tied the carb caps.
My pipe did expand a little bit over-all too, but I liked the pipe more afterwards, so i wasn't complaining.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 05-14-2003, 01:15 PM   #6
fraz's Avatar
Send a message via AIM to fraz
I do this all the time. I fixed one pipe last night and have another in the freezer now.
To block the big hole I have an exhaust coupler with a 1/2" socket extension zip tied in it. The steel will help the water freeze faster and seal the gap. My friend who taught me about the steel actually has a section of steel rod that is the correct diameter to fit in the opening but I made do with what I had. Then I push the open end of the coupler on the pipe and zip tie it tight. For the stinger I block it with an old bent pivot ball and electrical tape is the ticket for sticking while it is still wet.
The process kind of goes like this:
1) Pull off a 1-2' long piece of electrical tape and stick on counter.
2) Zip tie blocked exhaust coupler to pipe
3) Fill sink with water
4) Submerge pipe and fill with water (critical point #1 is to shake it around to get all air bubbles out)
5) With pipe still submerged, put pivot ball in stinger facing upward.
6) In left hand, put thumb over pressure nipple and lift straight out of water with stinger facing up. (critical point #2 is do not lose any water)
7) Grab electrical tape in right hand and wrap around the diameter of the pipe and pivot ball slowly but tight while not losing water.
8) Gently place in freezer at that same angle. Make sure you have something in your freezer to prop the pipe up so the stinger is facing straight up. I use a couple of old rubber sedan tires
9) Let freeze for 4-6 hours. If there are still dents, thaw in warm water and repeat 1-8. I had one pipe that took 6 times but it finally looked and worked great.
I thought about the zip ties around the pipe to fight over expansion but my fear is I'd end up with a turbo ring looking pipe.
WARNING: If there is any hole in your pipe including a pinhole in the weld, this with likely destroy the pipe and blow it open.
If anybody doesn't understand and sees me at the track, ask me because I have these pieces in my toolbox and I can show you.
fraz is offline   Reply With Quote
Old 05-14-2003, 01:17 PM   #7
fraz's Avatar
BTW, Troy I found a couple of my over expanded [pregnant snakes] 9886 1/8 onroad pipes worke really well too.
Old 05-14-2003, 02:02 PM   #8
chachi's Avatar
fraz:
how do you plug the pressure nipple, or do you plug it at all?
also, will a crack around the base of the stinger rip open?
Old 05-14-2003, 09:44 PM   #9
VoneRkid's Avatar
fraz:
You use fuel tubing and a ziptie.
VoneRkid is offline   Reply With Quote
Old 05-15-2003, 12:13 AM   #10
THeGame's Avatar
Send a message via AIM to THeGame
this does work i have done it ..
when you do it lean the pipe up so that the bottom of the pipe is down. then frezzzzz it ..
ones its done just poor some hot water on it... And your good to go...
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 05-15-2003, 12:32 AM   #11
VoneRkid's Avatar
It fix my Mugen pipe....
Damo
single or dual chamber tuned pipes? aznrevlazn Nitro On-Road 1 12-15-2007 11:06 AM
Associated Dual Chamber Tuned Pipe. NitroMaxx3.3 R/C Items: For Sale/Trade 9 06-08-2007 12:25 PM
3 chamber pipes nathan g Nitro On-Road 1 05-06-2006 09:20 PM
Golden Honrizon's 1/8 dual chamber pipe sammycat32 R/C Items: For Sale/Trade 1 06-19-2005 10:24 AM
NIP FT NTC3 Dual Chamber RE Pipe 45$ Got Rice? R/C Items: For Sale/Trade 0 08-19-2002 01:36 PM
