Old 05-12-2003, 09:56 PM   #1
puma1824's Avatar
Send a message via AIM to puma1824
Default CA Tire Glue - what would you suggest?
I keep ripping off my tires on my Nitros...
Which brand and consistency (thin, med, thick) would you suggest?
My local LHS only has the generic stuff which doesn't work for me
thanks,
Puma
puma1824 is offline   Reply With Quote
Old 05-13-2003, 01:57 AM   #2
sausage_link's Avatar
Send a message via ICQ to sausage_link
i use Flash CA and its consistency is Thin
hope this helps
wat brand are u using?
sausage_link is offline   Reply With Quote
Old 05-13-2003, 02:03 AM   #3
FREAKAH's Avatar
Yep! Those generic re-labled stuff is a waste or money.
I currently use the Losi thin tire glue with excellent results. The included teflon tube ensures a mess free job too.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-13-2003, 02:36 AM   #4
rrgt_kid's Avatar
i use flash thin and its in a pink bottle!
but about 10 years ago when i was flying planes i used to use some other that we got from the states but it aint around anymore and it was top stuff!!!! :
jeremy
rrgt_kid is offline   Reply With Quote
Old 05-13-2003, 02:49 AM   #5
FREAKAH's Avatar
Was it Hot Stuff?
Second-Hand Racing
RACE WORLD HAWAII
Old 05-13-2003, 10:18 AM   #6
popsracer's Avatar
Guys;
From past experience, stick with a Tire specific CA glue. The general hobby CA's don't work as good.
Tire/Rim prep has a large impact on how strong the bond is. Make sure the Tire and Rim have been throughly cleaned to remove any molding residue and it helps to scuff up the Bead area on the Rim & Tires with a Dremel or Sandpaper.
PS, Keep a bottle of DE-Bonder handy.
popsracer is offline   Reply With Quote
Old 05-14-2003, 01:40 AM   #7
rrgt_kid's Avatar
Originally posted by FREAKAH
Was it Hot Stuff?
i cant exactly remeber!.
jeremy
Old 05-14-2003, 01:45 AM   #8
Manticore's Avatar
R/C Tech Charter Subscriber
check out some industy grade CA. they have different spec such as application and drying speed.
look for spec especially for rubber and nylon and i think you dont need a CA with drying speed of 3 seconds.
Manticore is offline   Reply With Quote
Old 05-14-2003, 03:20 AM   #9
FREAKAH's Avatar
Default Re: CA Tire Glue - what would you suggest?
I wash the wheels and tires in a 20/80 solution of Simple Green and warm water for ten minutes and then rinse thoroghly and let dry. A good dish soap like Dawn works great also.
Second-Hand Racing
RACE WORLD HAWAII
Old 05-14-2003, 05:56 AM   #10
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
ever since I started scuffing the rims and tire bead with a scotch brite pad,then washing with detergent(dishwashing or simple green) I've had no more problems..
also,LOSI tread lock is the best I've found..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 05-16-2003, 12:10 PM   #11
TRF_TG10R's Avatar
SUPer Glue!!
TRF_TG10R is offline   Reply With Quote
Old 05-16-2003, 01:19 PM   #12
NTC3NUT's Avatar
Losi CA is some of the best. If you use the thick stuff it gives you a little time to correct mistakes, and it will outlast the thinner stuff. No matter what you prefer, they make it all. And yes, debonder & accelerator are good things to have.
NTC3NUT is offline   Reply With Quote
Old 05-16-2003, 03:19 PM   #13
THeGame's Avatar
Send a message via AIM to THeGame
Default Losi CA
i 2nd that.. Its awsome..
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 05-17-2003, 03:42 AM   #14
FREAKAH's Avatar
Default 5/8 FULL?............C'MON!!!!
I just wish Losi would fill the bottle up all the way .
Second-Hand Racing
RACE WORLD HAWAII
Old 05-17-2003, 04:09 AM   #15
if your tyres are falling off then i wouldnt blame it on your CA sounds like your tyres are too big for the rim and your relying too much on teh CA to keep em in place
i found that even super glue works
tire glue HELP jedsled Electric Off-Road 9 04-16-2008 06:27 AM
Best tire glue LogiK Nitro Off-Road 28 04-12-2008 10:09 PM
TIRE GLUE pink_sleeve Electric Off-Road 27 11-29-2007 07:42 AM
Tire Glue tonyking73 Rookie Zone 4 03-21-2007 02:18 AM
Tire Glue HELP srowell3 Nitro On-Road 1 02-22-2007 12:59 PM
