Old 09-11-2007, 03:50 PM   #1
Unhappy Someone Please Help
i have a HPI RS4 3 and the pullstart won't retract i've tryed 2 different pull starts and 2 different 1 way bearings and still the same, does anyone know what else it could be???
Wreckless_Daz is offline   Reply With Quote
Old 09-12-2007, 12:17 AM   #2
rudeboy's Avatar
Let me give you some advise:Just Go NonePullthrust me
rudeboy is offline   Reply With Quote
Old 09-12-2007, 04:32 AM   #3
quietstorm76's Avatar
Maybe you are putting the one-way in backwards. Did you use a new pull starter. The new one should have retracted. There's a coil spring inside that makes it retract and if it's bound up you'll have to take it apart, but I've done and it sucks.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 09-12-2007, 05:43 AM   #4
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
If you had the engine apart, you might have not slide the crank all the way back in and it could be jamming the pull starter.
If you look at the cost of bandaids for the blisters you will get on your fingers and the agrivation, the starter box is the way to go. get rid of the pull start and you will also get more power out of your engine. And it will give you more options for engines that you can run. I know it sucks that you have to spend more $$ for a starter box, but in the long run, it is a very good investment.
rcfoolz is offline   Reply With Quote
