Old 05-03-2004, 04:17 PM   #1366
Aggdaddy's Avatar
Yeah, you gotta get one. Especially if you are racing and using setups from other people.
I'll post pics of mine soon.
Aggdaddy is offline   Reply With Quote
Old 05-03-2004, 04:21 PM   #1367
bballer's Avatar
Default aggdaddy
How is the quality of the pmb one? All i need is something to get the job done.
bballer is offline   Reply With Quote
Old 05-03-2004, 04:26 PM   #1368
bballer's Avatar
Great, I just opened up my sts rs3 for routine maintenence after break-in and i found the conrad has a lot of play. Well, I called the importer team crc and they said they will probably be able to send me a replacement for free and thats the good news. Sadly, though, i don't have another engine so Ill be without my beloved g4 probably until next week. I may as well do a rebuild of the car and get it cleaned out. I might even bust out the xxx-s G+ for some good times While im checking out the car, i may try to mod the steering and see what happens, ill tell you how it goes.
bballer
Old 05-03-2004, 04:35 PM   #1369
Aggdaddy's Avatar
Default Re: aggdaddy
There was an earlier post that compared all three (PMB, Hudy and Integy)
This is my first one, so its just fine for me.
Price is the deciding factor for me. As long as its accurate and easy to use, I'll use it. Everything seemed to be ok with the board and the setup system.
The board is a little thinner than I thought it would be, but I prefer it to be light. Everything is easy to see and well defined. I know my track width now
199 in front and 200mm in the rear.
Old 05-03-2004, 04:58 PM   #1370
bballer's Avatar
Thanks, price is deciding for me too, and as long as it is easy to see, its perfect.
Now i just have to get all As on my semester and ill have one
Old 05-03-2004, 05:24 PM   #1371
impalabob64's Avatar
Send a message via AIM to impalabob64
Default trued tires
anyone run trued tires i run mine like joel johnson i race on prepared tracks here in fla. i found out when run new tires out the box the car reacts different it pushes .but i run smaller tire it handles like it on rails very fast alot team drivers i see run trued tires an they run the frts smaller. smaller tires makes my car handles when i drive it hard an goes where ever it is pointed.
g4-eclass
rody rbx12
fastest lap
15.06
Superiorhobbie
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 05-03-2004, 05:40 PM   #1372
Aggdaddy's Avatar
I just found that out this weekend too.
I am running 58mm front and 61mm in the rear and it gives me way more on-power steering.
I love it.
Old 05-03-2004, 06:36 PM   #1373
Formula1fan's Avatar
This is my first attempt at racing nitro. I have been racing my xray for a while. I ran a one-way in it once and could not do anything with the car. Has anyone tried the diff in his or her G4. I know I am not comparing apples to apples with xray to G4 comparison, but is the one-way easy enough to drive?
P.S. NITRO PIMP that girl is swollen around her colon. [email protected]#! She is bad!
Formula1fan is offline   Reply With Quote
Old 05-03-2004, 07:35 PM   #1374
KMac's Avatar
Formula1fan,
Love the tag line. SCREW the IRL and Tony George!!!!! What a bunch of second rate hacks!!
KMac is offline   Reply With Quote
Old 05-03-2004, 07:38 PM   #1375
KMac's Avatar
BTW, I've run both the one-way and the gear diff in my G4. Unless you're on a pretty big track with a lot of high speed sweeping turns I'd stick with the gear diff, especially if you have to brake going into any corners. My local track has a 105 foot straight and a lot of smaller turns and I was getting my a$$ handed to me regularly when I had the one-way in. I put the front diff back in and took 1.5 seconds off my average lap time, plus I'm hitting the boards less often.
Old 05-03-2004, 07:41 PM   #1376
Thumbs up have a tip for g4 drivers
Hey guys i forgot to give very important tip for all g4 drivers this a good thing to knew if u hve any problems with g4 rear belts wearing or breaking at a race an u hobby does not hve in stock an they carry serpent belts the 235mm car from serpent the rear belt off the 235mm fits 100% perfect found out at a staterace when i lost mine an its wider an stronger. Im still using it
RoninRc.com
Basher BT-4
Old 05-03-2004, 08:45 PM   #1377
Default setup for short track
Hey guys short track setup,this will work for u guys that run short tracks.Ok u need get a frt diff the reflex nt diff works.When u build it make shore u run 120,000 diff lock by ofna,the in the rear run 30,000 diff lube. The frt will act like a solid axle which will pull through corners fast. Make shore u run trued tires smaller in the frt.This is my setup try it an think u will be amazed.
Frt
Droop2mm
Toe1%+
caster4mm
[email protected]
Rideheight4.5
DiffFluid120,000 Ofna difflock
REar
Droop3mm
Toe-2
Diff Fluid 30,000
Rideheight5mm
GEARs
20/52
24/48
RoninRc.com
Basher BT-4
Old 05-03-2004, 08:47 PM   #1378
Aggdaddy's Avatar
An MTX-3 rear belt works good too.
Old 05-03-2004, 08:51 PM   #1379
Default Re: setup for short track
Frt
Droop2mm
Toe1%+
caster4mm
[email protected]
Rideheight4.5
REar
Droop3mm
Toe-2
Diff Fluid 30,000
Rideheight5mm
GEARs
20/52
24/48
fastest lap 15.09 SuperiorHobbies ORlandoFla.
RoninRc.com
Basher BT-4
Old 05-03-2004, 08:59 PM   #1380
Do i just pick up the gear diff for the front from the C-Class??
Mike
budlightnmyhand is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
