Old 05-01-2004, 12:21 AM   #1321
OK good, I've got ellegi 40 shore 26 fronts and 37shore 30mm rear.
Now if only the damn car would get here already! lol
Offhand question any suggestions for glowplugs for an novarossi nsr5 5port turbo running maxys 30% nitro in humid florida weather?
Brightbluehaze is offline   Reply With Quote
Old 05-01-2004, 12:28 AM   #1322
rjl
rjl's Avatar
Use at least .4mm head shim and 6 or 7 tf.
rjl is offline   Reply With Quote
Old 05-01-2004, 01:21 AM   #1323
impalabob64's Avatar
Send a message via AIM to impalabob64
Default glow plugs
when running 30% here in fla. i run a cold plug mc9,odonnel 77.tires 37shore all around for now but as it gets hotter u mite want to go 40,s.
Rody RBX12
70w frt blue springs
60w rear kit springs
37 shore frt,rear
fastest lap 14.05
Magnum Racing HBS
Dayton Beach
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 05-01-2004, 01:26 AM   #1324
Default turboplugs
novamega #6 turboplug, just run a cold plug as far as turbos
RoninRc.com
Basher BT-4
Old 05-01-2004, 08:56 AM   #1325
raffaelli
Hey Mr BrooklynRC,
what new deal????
brooklynrc is offline   Reply With Quote
Old 05-01-2004, 01:05 PM   #1326
You guys
I drove my car again today. Man that superglue is holding the rear shock mount so well. It even jumped a crack and was like 1 1/2 inches in the air and still didn't break. It still fun and i can control this thing so well even though its only running rear wheel drive. I still think i need to stiffen up the rear gear diff a little bit. Wow this this is pretty damn fast though. I was running the motor at about 230 degree's and i started to learn her out a little. Its getting faster and faster every time Thanks for all your guys help.
KMAC,
i still can't tell if my 2 speed is shifting into second. I did what you told me and held the car in the air and reved it but didn't feel anything. I think i have it to tight still.
This is so fricken cool. I'm painting a new race body now. I'm getting it all liquid masked up right now. I'm going to run the vaxhaul vectra.
I have had no problems with the steering what so ever. I have this thing running so strait when i do not have my hand on the steeringwheel. I just lined it up by sight basically and i also used the integy setup station to get everything close to even. I may need to drop it down a millimeter, droop wise. Other than that, this car is fricken sweet!!!
One more question, how much longer will my car run with the bigger gas tank? Thanks,
Mike
budlightnmyhand is offline   Reply With Quote
Old 05-01-2004, 03:04 PM   #1327
you shouldnt lean your motor no more. if you running at 230 you already running lil hot. optimal operation temperature for these motors is 200-225 degrees ferenheit. if you get abouve 250 you takin chances.
also dont forget while you running that you got low end needle and idle. i wouldnt suggest messing with midrange needle.
Old 05-01-2004, 03:10 PM   #1328
I've never touched the needle everyone says not to. I have 4 adjustsments on my carb. High, low, something else, and idle. I have never touched idle or the other one i think its the main needle or something.
Ive read that people run their rossi motors near 260 to 280 with no problems. Next time i run it i will make sure i keep the temps down a little more. I'm not to worried. I have a nova mega 5 port turbo engine thats a back up if i mess this one up
Mike
Old 05-01-2004, 03:25 PM   #1329
Here this is from this website
http://wildhobbies.com/news/default....&articleid=959
Is It Set Right?
The best way to tell if the motor is tuned properly is by testing the temperature of the motor. Each motor is a little different so consult the motor's owner's manual or website to find out what the optimum temperature of the motor is. This is usually between 230 - 260 degrees. There are some motors that run under that range and even some that prefer hotter temperatures, so again, check with the motor manufacturer.
Old 05-01-2004, 03:36 PM   #1330
ya each motor is different, i have few guys that run nocamegas on my local track and sometimes temps are 280-300 and the motors are fine.
if you run it cooler you are prolonging the life of the motor. and you are right novamegas do run lil hotter. but i still use caution on mine
Old 05-01-2004, 03:51 PM   #1331
I ran the car around going in circles cutting back and forth sometimes WOT sometimes not for about 3 min then i did a WOT shot right to me and then when it got to me i took the temp with my temp gun and it was like 230.8 or something so i think its pretty good. It still isn't broken in all the way but i have ran total about 8 or 9 tanks through it and they all have been very rich (spitting excess fuel out the pipe) you could see the fuel on the cement. I think i'm doing pretty good since this is my first car and considering i bought it already put together and i didn't know if the other person messed with the carb settings or not. Its all a big learning process.
What would i need to do to stop my car from spinning out. I think it has alot to do with it only being 2 wheel drive right now and the fact i'm running rubber tires. What chassis adjustments do you usually make? Is there a website i can check out on tuning the suspension?
THanks,
Mike
Old 05-01-2004, 03:56 PM   #1332
Holy crap guys, i ordered my universal shafts from tower 2 days ago and they are fricken here already from nevada!!!!!!!!! So is my spring set for my shocks. WHat would be the best springs to put on the front and for the back. I bought the Reflex ones i got 4 pairs.
Thanks,
Mike
Old 05-01-2004, 03:57 PM   #1333
bballer's Avatar
go spend more money lol and get a xxx main chassis setup guide. They are well worth the 15 bucks and teach you everything about a cars handling
bballer is offline   Reply With Quote
Old 05-01-2004, 03:59 PM   #1334
bballer's Avatar
For the shocks I would just keep the stock silvers, and then try a softer rate since you'r running rubbers
Old 05-01-2004, 05:31 PM   #1335
Nitropimp's Avatar
bballer- GREAT advice just ordered a copy for my son.
thanks
Nitropimp is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
