Old 04-03-2004, 08:59 AM   #871
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
you should try softer tires......maybe 40/40 will work good.....
the tires wear more easily when you car rolls or spins......
running softer tires you'll probably get better traction and lower wear......
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-03-2004, 03:52 PM   #872
bballer's Avatar
Hi all, just finishing the wiring on my g4, following the guide on tm's wbsite. Just have one quick question: Is my radio going to glitch if the anteanna passes close by the servo wires? What have you done to fix that?
thanks
bballer is offline   Reply With Quote
Old 04-03-2004, 05:13 PM   #873
the antenna is not the big problem......
you MUST fix you receiver with 2 layers of double sided tape, the vibrations cause glitches due to the receiver holder is close to the engine......if you can afford, you should buy the kfactory carbon fiber transponder holder, the piece comes with an antenna holder and you can put it on the carbon plate above the receiver......
Salvadori Racing
Old 04-04-2004, 06:44 AM   #874
bballer... Just to prevent any glitching or lose of signal, I would mount my antenna wire right above my receiver. I did after losing single on 3 different occasions with my brand new M8 radio... I re-wired the car and problem solved... Funny thing, Trintity drivers Mike Dumas and prior driver Josh Cyrul mounted there's that way... Check out Hi-Torgue's R/C Car magazine page 54 Dec 2003 and RC Car Action Dec 2003 page 204 and 205. You want as much antenna wire exposed to the air as possible and not snaking through the chassis and over servo's... Also Carbon fiber is known to cause glitching as well... Also use double sided tape on both sides of your servos just as an extra measure of protection. You can mount as per the manuel or any tips found in the forum. I mounted my wire that way and I don't glitch period... Unless some idiot turns his radio with my same channel/crystal...
.02
RC_Alan
rc_alan is offline   Reply With Quote
Old 04-04-2004, 05:12 PM   #875
Scrad's Avatar
Trader Rating: 15 (100%+)
Does anyone here run Jaco foams. If so what color and shore ratings. I was trying to compare them to the purple and magenta the kit calls for but couldn't find shore ratings for the Jacos. Thanks.
Scrad is offline   Reply With Quote
Old 04-04-2004, 05:15 PM   #876
you should run JACO NITRO SHOES.......
40 shore front and rear always run fast and consistent......run 45 rear on track surface with too much bite.....
Salvadori Racing
Old 04-04-2004, 05:23 PM   #877
Scrad's Avatar
What are the colors? The reason I ask is we have a box of foams at work and they are half price to get rid of them, but the boxes don't have shore ratings on them.
Old 04-04-2004, 05:27 PM   #878
JACO NITRO SHOES have no color identification.....
only the foams for carpet racing are identified by color.....
Salvadori Racing
Old 04-04-2004, 05:42 PM   #879
impalabob64's Avatar
Send a message via AIM to impalabob64
Cool hey
hey i race here in fla. the tire shore combo depends on temp of the day an if its a permanent track or parking lot track.On a permanent 37all the way around works great here in fla. when the temp is up in the 90,s 40,s all around. now on parking lot tracks here 40 frts an 37rears or 35 rears work also.on my g4 i use 37s all around.an i,m still the only G4 driver here in fla.but this baby is taking names u knew like mtx3 an 710.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-04-2004, 05:48 PM   #880
Thumbs up tires
the tires i use are the take -offs they hve the tire shore on the box or the fast tires try one of those brand an it should help
RoninRc.com
Basher BT-4
Old 04-04-2004, 08:16 PM   #881
Aggdaddy's Avatar
Jaco's didn't really work too well for me. They seem to break too easily. I tried using new Mono Touring tires on my rear and they helped bring my lap times down. Didn't chunk either. Although I was using some used Ellegi in the front. I think that might have created an overdrive ratio.
I use 37 shore all around for my track.
Aggdaddy is offline   Reply With Quote
Old 04-04-2004, 09:50 PM   #882
KMac's Avatar
Need help fast!......are the front steering knuckles and the rear uprights on the G4 interchangeable/same as on the Reflex???? ----or are they the same as on the V-one RR, etc.....? I gotta get these parts fast.
KMac is offline   Reply With Quote
Old 04-04-2004, 10:03 PM   #883
Aggdaddy's Avatar
I think the rear knuckles are skinnier.
Old 04-05-2004, 04:47 AM   #884
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default FOAMS
I will be using two brands this year:
TRC and GQ foams. I like the GQ foams because they are durable and come on orange rims. The TRC last a decent time too but they only come on the yellow rims.
RCNUT is offline   Reply With Quote
Old 04-06-2004, 09:27 AM   #885
Default Question
Hey all,
I have a chance to carry the PMB set up stations. The problem is that it is very expensive to ship less than 10 to the US. Is this something you all would be interested in. The products sell for:
Set up station $55
Set up board $35
Shock set up too $23
check them out at www.pmbproducts.com and let me know. I will be their only US Dealer and I want to make sure it is worth it to order 20 -30 kits at a time. I see dinball and mushrrom selling the for a little more than I will.
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
