Old 04-01-2004, 04:13 PM   #856
xtreme888-
race report on link below, Ben Kelsall took the win, 2nd Mark Green, 3rd Chris Slater, wasn't there in person had to work, but am traveling down to mendip this weekend for the rubber national
http://www.trackside.co.uk/tibshelf%20rd1.htm
jas1 is offline   Reply With Quote
Old 04-01-2004, 08:02 PM   #857
Aggdaddy's Avatar
Default Nitropimp
Hey, how does that G4 drive compared to your Yokomo GT-4 that you are selling?
Aggdaddy is offline   Reply With Quote
Old 04-01-2004, 09:04 PM   #858
Nitropimp's Avatar
Default G4 and Yok
Although my G4 is 80% done I've driven my friends G4 and it's like night and day. The Yok is nice but tends to get away from me in turns. Where the G4 just sticks around turns. I've tried everything on the Yok and my driving style just don't mesh.
Nitropimp is offline   Reply With Quote
Old 04-01-2004, 09:23 PM   #859
Aggdaddy's Avatar
It pushes or does the back-end kick out?
Old 04-01-2004, 09:26 PM   #860
Aggdaddy's Avatar
Hey, I've taken a few pics of my G4 after my recent mods.
Check it out.
http://www.geocities.com/aggace/g4-page2.html
Old 04-01-2004, 10:26 PM   #861
Nitropimp's Avatar
It pushes...... I race a small tight track and the gear even with the right gearing just can't keep up. I really like low CG car. TC3's just tear my track up. I tried the G4 and like it. I also love the Mugen MTX-3 both cars are great. Once I convert my V one RR to an evo it should be a contender..... BTW-Nice looking car!!!
Old 04-01-2004, 10:39 PM   #862
Aggdaddy's Avatar
I started out with a HPI Super Nitro then a Nitro rs43 SS. So I'm still use to driving a car with a front diff and four wheel braking. I drove a TC3 and I really missed the ability to brake hard in the corners. I felt more at home with the TC3 than the G4. Our track in Houston is sort of like a medium track with tight turns. So, I think the stock G4 gearing is ok for now, until I get a better feel for the car.
My G4 is kind of a novelty to me, because I'm still trying to get use to the driving style.
Thanks for the compliment Nitro P .
Let's see some pics of yours.
Old 04-02-2004, 04:21 PM   #863
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default TM Touring Bag
Hey all,
My distributor got the tm bag in. I bought one to check it out and it is awesome. I am ordering more for Wednesday delivery so if anyone wants one let me know. [email protected]. Ground shipping will be $11 because boxed up it wieghs 15 lbs. The bag will be $70.00. Email me for pics of it.
RCNUT is offline   Reply With Quote
Old 04-02-2004, 04:36 PM   #864
Default Tyres Size For E class
Hiya,
This is gonna sound like a silly question , but could anyone out there tell me what is the standard setup split ( diameter different between front and rear ) ? What is the OD ratio for using standard pully, and also what is the starting diameter for both end ? This is a 4 wds car, hence overdrive must falls into the equation somewhere !!!
xtreme888 is offline   Reply With Quote
Old 04-02-2004, 04:47 PM   #865
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
the g4 overdrive is ~1,3.....
don't worry about the different diamter between rear and front tires......
it does really matter only due to the tire wear, maybe rear tires 1mm bigger than front will work good for an entire race, but the overdrive almost not chance using even diameter or bigger diameter for the rear tires....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 04-02-2004, 08:15 PM   #866
Nitropimp... I'm using the special 26 tooth side pulley to add more on power steering... I really does work very well... The G4 does tend to push a little bit, but that's due to track conditions change from day to day... I just got my copy of RC Car Action and read Joel Johnson's article... Very good reading, but I must say the Endpoint adjustment-Step 13 is key and your duel rate settings as well... Also where you mount your steering servo ball stud. I mount mine on the lower hole to have a true horizontal/movement left to right... The manual on page 23 says it should be parallel with the sliding steering rails... To keep from going through steering servo savers this is very important and if you mount the ball stud on the steering servo arm on the lower hole, you'll have to adjust your endpoint and dual rate for the lack of throw, but your steering will be smooth and servo saver won't prematurely wear out... If you mount the ball stub on the top hole.. Like Joel Johnson, on page 142 step 6, you'll have more throw, but your servo savers won't last long either and you could ruin your steering servo as well. The binding issue Joel Johnson speaks about is true also and should be checked closely when setting your EPA. This tip is for all G4 owners new and old... Joel might have missed that one... Kmac and Nickko posted good tips on this as well.... It's great to see Team drivers from Trinity backing the G4 in RC mags as well... Oh, I see he likes to use the KO Propo servos as well... Sanwa's work fine also for those who like them...
RC_Alan
rc_alan is offline   Reply With Quote
Old 04-02-2004, 08:43 PM   #867
Default in stock update
Below is a list of parts that I have in ready for delivery. As always they go fast.
K1419 updated fuel tank $32.00
k1475 4mm chassis $75.00
k1418 clamp hex hubs $16.00
k1457 hard ctd 18t pulley $17.00
k1462 universal set(pair) $50.00(have 1 left)
k1411 alum rear solid axle $33.00
k1430 carbon bumper plate $26.50
k1461 hard ctd 19t brake pull $23.50
k1434 alum brake lever $13.00
k1420 alum middle shaft $12.50
k1429 alum front lower bump $34.50
k1432 alum steering rail mount $17.50
k1427 alum servo mount $34.50
k1401 low fric front belt $12.50 (1 left)
k1402 low fric side belt $12.50 (2 left)
k1403 low rear belt $12.50 (2 left)
k1470 alum steer servo saver $24.50 (3 left)
As always if you spend $100 you get free priority shipping. Email me at rcnutshobbies.com
Old 04-02-2004, 09:59 PM   #868
Aggdaddy's Avatar
Default battery for G4.
battery for G4.
If you haven't bought your G4 battery yet, try http://www.kinetixrc.com/
I just bought a backup receiver battery for 15 bucks.
750Mah
Old 04-03-2004, 07:04 AM   #869
d.a.d.d.4's Avatar
Thumbs up
thanks for the link aggdaddy
d.a.d.d.4 is offline   Reply With Quote
Old 04-03-2004, 08:22 AM   #870
Default 26mm rear
hiya guys,
have anybody try running 26mm front tires on the rear instead of 30mm ? if yes, how was the car handling affected ? Rear tires are wearing twice the rate of front ( 42` rear & 45` front ).
thanks
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
