Old 03-29-2004, 04:14 PM   #826
KMac's Avatar
It's the cups that come with the k factory front one-way.
Right here:
http://shop.the-border.nl/customer/p...cat=437&page=3
KMac is offline   Reply With Quote
Old 03-29-2004, 05:41 PM   #827
Aggdaddy's Avatar
Did your G4 not come with the one-way? Did you have to buy yours seperately? Probably doesn't have much to do with the problem you're having, but it seems like a simple problem that can be fixed with a replacement part.
Aggdaddy is offline   Reply With Quote
Old 03-29-2004, 07:32 PM   #828
Nitropimp's Avatar
Hey guys I know I have to put the G-4 on a step up board before I go on the track. But on page 11 Step 5 the front assembly setup. The book says 33 mm (inside specs) for the steering rods. This can't be right my car looks like it just hit a crack pipe. 33mm?????
Nitropimp is offline   Reply With Quote
Old 03-29-2004, 07:34 PM   #829
Regional Moderator
daniz24's Avatar
Originally posted by KMac
Anybody know the part number and stock status of the drive cups for a front one-way? Every time a dogbone pops out the drive cup falls out as well. So far I've been able to find it every time but I fear my luck will soon run out.
Also, are there longer dogbones? Stopping every 10 minutes to look for the dogbone and drive cup and re-installing them is starting to piss me off royal!!!! I tried a dogbone off of a Yokomo GT-4 (it's 56 mm vs 52 for the G4) but it's just a hair too long and will cause binding. It looks like a 54 mm will be the perfect length.
KMac,
Yes. Team Magic did produce longer dogbones, and it includes in the newest kit batch. With longer dogbones (55 mm) you don't need those o-rings anymore. But I have aproblem using these dogbones for rear as they're too long for 198 track width. I just replace it with Kyosho (52 mm)
Here's the part# :
K1409-1 G4 & V1 One-Way Joint Cup (2)
daniz24 is offline   Reply With Quote
Old 03-29-2004, 07:43 PM   #830
Regional Moderator
daniz24's Avatar
Yes, it is 33 mm. But of course you have to re-setup again since mostly people use diferent trackwidth and of course it infects your front toe adjusment. Feel free to adjust it, just remember that those right & left turnbuckle length has to be equal. This is a good starting point to have steering balance.
Old 03-29-2004, 08:32 PM   #831
Nitropimp's Avatar
Super Fast shipment from HK!!! Thanks..........................,AAA++++!!
Really I must being doing something wrong. I have them set at 33mm both sides and Front hubs set at 3mm and 2.5mm for the bottom and this is what I have. The wheels look JACKED. As seen in the pics. This is with the steering rail in the center. What I'm I doing wrong??....
Can anybody see from the pics what I did wrong?????
Old 03-29-2004, 09:00 PM   #832
Aggdaddy's Avatar
Looks like you have your tie rods too long. That should be fairly obvious. There's nothing else that you can adjust for that either.
So, just make 'em a little shorter. Maybe you are measuring it the wrong way?
Oh, I just noticed. Those steering knuckles aren't stock. Maybe there's a different adjustment for those and then 33mm for the stock steering knuckles.
Old 03-29-2004, 09:09 PM   #833
Nitropimp's Avatar
Yeah the steering hubs are not stock. AAAAA that's the prob. Man... AggDaddy come out to NorCal and I owe you a lap dance.... Thanks......
Old 03-29-2004, 09:15 PM   #834
Aggdaddy's Avatar
Glad to help out a fellow nitro tourer. I see you already have some hot mods installed. Good luck on your maiden run.
Old 03-29-2004, 09:25 PM   #835
KMac's Avatar
Your problem is with the aftermarket steering rack/servo saver. It has the ball ends mounted further out than on the original plastic one. You have to shorten the tie-rods to account for it.
Old 03-29-2004, 09:36 PM   #836
Nitropimp's Avatar
Thanks...... I'm going to put it on a setup board. I totally forgot about the Hop Ups affecting the stock stearing setup. Sniffing to much Nitro Fuel... Hopefully have the car ready this weekend. One last question I know Rc_Alan likes KO servo but what's a good steering servo that you guys suggest???? Throttle shouldn't be a problem, right?? Just the steering because there's not alot of room to mess with, right?
Old 03-30-2004, 12:11 AM   #837
Regional Moderator
daniz24's Avatar
Yes this is true. With the K-factory servo saver, you have to shortened the tie-rods about 3 mm.
Old 03-30-2004, 12:13 AM   #838
Regional Moderator
daniz24's Avatar
I prefer Sanwa VX (Very high torque to reduce posibility for broken servo). And I think Sanwa servo is the most fit in shape for TM G4 steering.
Old 03-30-2004, 12:19 AM   #839
Nitropimp's Avatar
Daniz24- Yep 30 mm was the magic number..... That threw me off!!!....
This is the Blue Man Car..... She almost done. Here's a pic.
Old 03-30-2004, 09:05 AM   #840
Regional Moderator
daniz24's Avatar
Cool.... Mine is all silver Hey, I notice that you don't use the alum hex wheel and rear belt tensioner. Go get 'em !!! Those are the most important optional parts for G4.
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
