Old 02-08-2004, 09:39 PM   #496
Trader Rating: 49 (100%+)
Default Rear Diff Oil Question
So what's the rule of thumb on rear diff oil?
What does lighter oil (3K-10K) do for you?
What does a heavier oil (30K+ ) do for you?
I have typically run 20K-30K in front and 5k-10K in the rear. But lately, I am having people tell me the I really need to tighten up the rear with at least 30K oil.
I always thought lighter weight oils gave better traction and heavier oils took away traction.
rodneybarrett is offline   Reply With Quote
Old 02-10-2004, 06:17 AM   #497
dameetz's Avatar
Originally posted by Scott B
HI guys, I got another question. I know some parts from the Kyosho cars fit the G4, so will parts from the reflex fit to since the reflex is based off the Kyosho ie..... belts, gear diff, arms etc...?
As I said earlier I don't have Reflex but if it fits V1R it will fit G4. As for belts if your Reflex uses 27 front side pulley then it will fit perfectly. i myself using some of my V1RR parts such as Diff, belts and pulleys. Hope this helps.
Note: you cant's use V1RR EVO front upper and lower arm because it is a bit long.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 02-10-2004, 06:52 PM   #498
Registered User
Default question for dameetz
hey dameetz i see you have a mtx 3 and g4 i am going to get a new car and was picking between those two what one do you like better thanks jesse
J FAST is offline   Reply With Quote
Old 02-11-2004, 01:39 AM   #499
nickko's Avatar
Send a message via MSN to nickko
K1471 G4 Carbon Brake Bracket (w/alum. belt tensioner)
K1472 G4 Shock Piston (#1, #3, #4) (6)
K1473 G4 Caron Rear Shock Tower Stiffener
K1474 G4 New Alum. Middle Mount
K1475 G4 New 4mm Lightweight 7075 Alum. Chassis
nickko is offline   Reply With Quote
Old 02-11-2004, 08:59 AM   #500
dameetz's Avatar
Default Re: question for dameetz
Handling wise I like G4 better!
Old 02-11-2004, 05:58 PM   #501
Default Re: Re: question for dameetz
Hey I've got a question for you if you would be so kind as to answer them, how do you like the G4 compared to the RR Evo?
In terms of maintenance, which has less if either? Also, what about prices for parts and what part of the world are you in?
Another thing, what kind of inherrent problems does the evo have?
Thanks.
Prozak is offline   Reply With Quote
Old 02-11-2004, 08:07 PM   #502
dameetz's Avatar
Default Re: Re: Re: question for dameetz
Thanks.
Actually I m very happy with all my cars. I like my G4 because it handles a bit better than my Evo and MTX3.
Maintenance wise I have to say RR Evo is alot easier to work on. G4 design is very compact, so there is not much space left, even for the wiring.
I live in South East Asia so the parts here is a bit cheap compare
to EVO.
I don't see any inherent problems with my evo so far infact between all my cars G4 is the one which give me problem initially(steering servo saver get stuck). You just need time and trial and error to set the steering rail set up properly.
Old 02-11-2004, 08:23 PM   #503
Cool, thanks for the response.
Old 02-12-2004, 06:05 AM   #504
Send a message via Skype™ to JordanC
Where can you buy them??
JordanC is offline   Reply With Quote
Old 02-12-2004, 06:11 AM   #505
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default Jordan
what are you looking for?
RCNUT is offline   Reply With Quote
Old 02-12-2004, 06:24 AM   #506
Magic!
Old 02-12-2004, 06:17 PM   #507
B
I am curious
How is the parts quality of this car? (Fit and Finish)
comparing it against Mugen or kyosho
Thanks guys
B is offline   Reply With Quote
Old 02-12-2004, 06:58 PM   #508
Originally posted by B
I am curious
Thanks guys
I would say; Excellent..!! I had no problem, and haven't broken anything yet from the car...
goodspeed is offline   Reply With Quote
Old 02-12-2004, 07:00 PM   #509
Default Jordan
sent you a pm.
Old 02-12-2004, 08:18 PM   #510
nickko's Avatar
Please find some tips for setup the G4 steering below.
http://www.teammagic.com.tw/phpBB2/v...hp?p=1018#1018
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
