Old 07-19-2005, 12:21 AM   #3076
Jye
Let me clarify.
SG=Centax Clutch
Threaded=3 shoe
Also, what type of battery pack is needed? Hump Flat, and how many cells?
Ive been looking for a kit that catches my eye, this is it . 166 dollars from towerhobbies too. Can you say cheap?!
Jye is offline   Reply With Quote
Old 07-19-2005, 01:09 AM   #3077
heavy's Avatar
Trader Rating: 20 (100%+)
That is a C-class and is very cheap. Comes with a front diff not a one-way and comes with the three shoe clutch which can be fitted to either type enginer - the clutch nuts for either type engine are included with that kit. The only major thing missing is there are no roll bars with that kit, everything else is good.
The battery is a 5 cell like AAA's three and two. If it fits a MTX3 it should be ok.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 08-05-2005, 12:51 PM   #3078
koldo is offline   Reply With Quote
Old 08-05-2005, 03:07 PM   #3079
afm
afm's Avatar
Originally Posted by koldo
Koldo
What you posted is the new UFO centax cluth picture, but no text?? what do you want to know about it??
AFM
afm is offline   Reply With Quote
Old 08-05-2005, 07:05 PM   #3080
Regional Moderator
daniz24's Avatar
Has anyone experienced the new UFO clutch, because I still haven't got mine
daniz24 is offline   Reply With Quote
Old 08-05-2005, 07:42 PM   #3081
daniz24... Check out the Mongoose/G4 thread... A few of us already have... I'll say this.... It's a must have if you're looking for speed and a super smooth system...
RC_Alan
rc_alan is offline   Reply With Quote
Old 08-05-2005, 09:04 PM   #3082
Regional Moderator
daniz24's Avatar
Hi Alan, I hope it's worth the money. Do you really can notice the differences?
Old 08-05-2005, 09:20 PM   #3083
For Joe average racer... I would say no they don't need it... Now if you're really into racing and want the very best performance out of your motor... Then yes, I would get the UFO clutch. The flywheel and clutch bell are a tad bit larger then before so keep that in mind. You can't slap the old clutch bell onto the new UFO clutch... To me... It's a must have if you're a serious racer and want to be a step ahead of the competion... Some hopups are just bling bling... This one really works...
RC_Alan
Old 08-06-2005, 12:46 AM   #3084
fenix's Avatar
Hi guys กก
i know this is the team magic g4 forum but have a doubt maybe an stupid doubt but somebody knows if i can use the g4 ball cups on my reflex nt or where can i find the bal cups for my car beside the trinity shop..
I ask this because i have a rpm ball cup of my rc10gt and this are bigger than the reflex ones...
BTW few weeeks more and i will have a g4 too
fenix is offline   Reply With Quote
Old 08-06-2005, 04:08 AM   #3085
fenix... The G4 ball cups should fit your Trinity Reflex NT... The reason your rc10gt ball cups didn't fit is because one is American standard size... the rc10gt and one is metric... the Reflex NT... Sorry for the spelling... It's 3am in the morning... lol...
RC_Alan
Old 08-06-2005, 04:10 AM   #3086
fenix's Avatar
RC_Alan
Thanks for your reply กกก
I will try it then ..
And have a good night / day
Old 08-23-2005, 01:57 AM   #3087
nickko's Avatar
Send a message via MSN to nickko
Default Team Magic 1/8 Bag
There are more & more world class drivers are using this bag now. Please check the product description below.
http://www.teammagic.com.tw/en/profr...9220&pageNum=1
nickko is offline   Reply With Quote
Old 08-23-2005, 12:43 PM   #3088
jaykay's Avatar
thats unbelievable nick!!!!
why do you spent so much time to build silly things like bags or 1:8 setup systems. the g4 had enough problems which have to be cleared. so put your brainpower into this!!
jaykay is offline   Reply With Quote
Old 08-23-2005, 06:33 PM   #3089
nickko's Avatar
Working on many things
Following text by Motorman
The UFO is radically different than the origional or even the s class clutch.
to start with the flywheel is slightly larger and heavier which allows the engine to idle smoother during pitstops and carry some off throttle inertia which is not bad for corner speed. It is deeper so the flyweights sit deep in the flywheel and the angle on the sides of the flywheel where the flyweights sit is a higher angle which makes the flyweights react quicker in engagement and disengagement for much better response and more consistant response. the pressure plate has an odd shape (looks like an upside down UFO, hence the name)that guides the flyweights straight so they don't cock against the flywheel pins, this allows the clutch shoe to hit the clutch bell straight on every time.(the flywheel pins are pressed into the flywheel perfectly straight so the disc won't hang up, they have to be more precision than a standard setup) The flyweights have 2 weights for tunability and the bell has three holes for venting directly in line with the clutch shoe contact patch (IE like cross drilled brake rotors) sealed clutch bell bearings come with it and they keep the bearings cleaner. and the best part is that when it hits it locks up and stays hooked hard everytime. The kit comes with the red spring but the orange option spring is the one to use set 1.5 threads below flush on adjustment to start with the bell shimmed to .6MM end play.
Unfortunatly everything on the system is all by itself even the clutch bell as it is slightly larger so only UFO bells will work with it. You have to use the entire system as a singular unit or it won't stack up right.
It would not suprise me to see other manufacturers follow suit on the UFO pressure plate design
Old 08-24-2005, 12:42 AM   #3090
hi nikko,
when come the ufo clutch with the car kit??? the original is a horror
when did you make a better fuel tank cap???that not leaks.
dieter
4racer is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
