Old 06-06-2005, 11:53 AM   #3001
Sorry for the late reply...
part numbers are...
TM502315 G4 Diff set ( w/2 diff cases, diff cover, gears, shims & o-rings)
TM502120 Front Nylon Pulley
jnims29 is offline   Reply With Quote
Old 06-06-2005, 12:45 PM   #3002
heavy's Avatar
Trader Rating: 20 (100%+)
Thanks guys - great help.
Is there any way of running a engine that doesn't have an SG type shaft. Is there a pilot shaft clutch nut that will fit and do the job ?
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 06-06-2005, 08:11 PM   #3003
Trader Rating: 44 (100%+)
part numbers are...
thanks for the useful info there!
is the TM502315 pack a new part? i believe it comprises individual parts such as
TM502115 G4 Diff Case (2), Diff Case Cover (1) & Gasket (2)
TM502116 G4 Diff Joint, P5 O-Ring, 5x12mm Shim & 2x11mm Pin
TM502117 G4 4x10mm Shim, Bevel Shaft & Bevel Gear Set (1)
If i had know there was a "G4 Diff set" then i would've bought it instead of the individual packs ..
wyl03 is offline   Reply With Quote
Old 06-06-2005, 08:52 PM   #3004
I believe it is a new part. The owner at my lhs just called RD logics and asked for all the parts to make a front diff. He also ordered me the new k-factory spool. Lookstrick anadized blue. I posted a pic under the mongoose thread.
Old 06-06-2005, 09:02 PM   #3005
shrabber's Avatar
Hey guys got a problem and need help please.I have a g4 c class.I have a .12 motor with slide carb and the slide carb only slides 1/4 of the way cause of the handle for pick up/fuel tank holder.Any suggestions thanks Tim [email protected]
shrabber is offline   Reply With Quote
Old 06-06-2005, 09:56 PM   #3006
Ffejdat's Avatar
You probably have to turn the carb a little, and maybe turn the barrel on the end of the slide so the linkage will clear the handle, Good Luck!
Ffejdat is offline   Reply With Quote
Old 06-06-2005, 11:41 PM   #3007
Regional Moderator
daniz24's Avatar
Yes, it sometimes happen when using OS or Sirio engines based engines. Some other engine will cause the crankcase is hitting by the disc brake. I have to dremel and remove some parts from the handle to get enough clearance for the carburetor.
daniz24 is offline   Reply With Quote
Old 06-07-2005, 06:21 AM   #3008
shrabber's Avatar
Dremel o ok I didnt know .I hate hack jobs.It looks like ill have to shave the handle to the nib.What a poor azz design.
Old 06-07-2005, 07:34 AM   #3009
Regional Moderator
daniz24's Avatar
Hey, blame the engine I believe on the first batch of MTX3, we have to cut the carbon upperdeck for carburetor clearance also. Or you can use 3Racing aluminum handle which perfectly designed to use with Lola body
Old 06-07-2005, 08:25 AM   #3010
shrabber's Avatar
Blame the engine a standard .12 w/slide carb?I have not seen this at this point before.There is alot of options that could have prevented this from being a issue not doubt.Where can I get a aftermarket part to ressolve it Thanks Tim Ps Thanks for your insight you seem to have good insight on this car
Old 06-07-2005, 09:01 AM   #3011
Regional Moderator
daniz24's Avatar
As I said before, only OS and Sirio carburetor has this problem. Other Nova based engine such as JP, Max, RB, IDM etc are all fine. Btw, I don't know where you can get 3Racing products in your area, but here's the picture. Thanks Part Number : G4-017
Old 06-08-2005, 06:34 AM   #3012
shrabber's Avatar
Anyone know what will have to be purchased extra if you get the k factory oneway front diff.Can you use the spur from old bulky diff or do you need to purchase something additional Thanks Tim
Old 06-08-2005, 07:16 AM   #3013
YBSLOW's Avatar
Default Same pulley.
Yes, you can use the pulley from the "bulky" diff on the K-factory one-way.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-08-2005, 07:24 AM   #3014
mtx3novapro's Avatar
HI would the G4 pro be better then the MTX-3 and what would be faster and better for the track
mtx3novapro is offline   Reply With Quote
Old 06-11-2005, 04:26 PM   #3015
shrabber's Avatar
Can Any one point me to a receiver battery pack for the g4 the one I got is to big thanks Tim
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
