Trinity G4 - Team Magic G4 E-Type
#2971
guys i have a promblem with the front belt from k factory when i put one new it is from the start not tight enought!!.... is this happening to you also?
#2972
The Team Magic G4, Mongoose, and VoneRR Evo are all the same cars, correct?
#2973
the rr evo is differend,but some parts of the rr wil fit the g4
#2974
G4:EVO:
More evo pics at:
http://www.kyosho.co.jp/web/products...one_rre-e.html
#2975
witch car wil it be they both looke very nice
#2976
The G4 and RR Evo are not the same. I have them both. The only thing they have in common is the 3 belt configuration. The front side pulley on the G4 is smaller than that of the Evo. Also the rear diff is more centered in the G4 as opposed to the Evo which sits towards the right side of the rear bulkhead. The gear ration is also not the same because it is much lower than the Evo.
The G4 uses s bellcrank style system for steering, where the Evo uses a center pivot.
Between the two cars the G4 has a lower CG, is lighter than the EVO, and also stiffer than the EVO.
#2977
New parts are in ;)
just too let all know we have a lot new parts in for the G4-Mongoose
like new clutch springs -steel cvd's -one piece engine mount-solid front axle- alu.steering system-
http://shop.the-border.nl/product.ph...8&cat=0&page=1
#2978
just got a g4 very happy with it handles great the car is on fire
#2979
If you have the G4 std E-Class or the Evo version, you wanna buy the new steering system, new steering block, and also the clutch update system. They're great improvement for the G4s.
#2981
Yes, you did very well.
#2982
As far as i know, the Team magic New G4 EVO already have included the new steering system ...
#2983
The new G4 has all the newest hop-up parts. I got mine 2 months ago.
#2985
bearing
joe try ebay item num 5977667890
