Old 03-20-2005, 10:24 PM   #2866
I just started testing a G4 E class with the new steering system and the new composite front upright that suppose to give more steering. I am also running the rear ball diff and front one way.
The car understeer a little at the sweeper during off throttle. and a little nervous everywhere. What can be done?
Does anyone have a good setup for a fast sweeper and smooth track? Got a race this weekend.
Current setup
Front
Spring Trinity yellow
Droop 1
stabilizer bar: flat
toe: out 0.5
shock oil Trinity 60
caster: forward max
tyre: 37
one way
shock angle: max incline
Track width: 199
Camber: 2
Rear
Spring std
Droop 4
toe: in 2
shock oil: Trinity 60
Tyre: 37
Ball Diff: heavy lock
shock angle: middle hole at shock tower, outer at arm
Camber: 4
Track width: 200
Body: Protoform Stratus 2.1
RunarounD is offline   Reply With Quote
Old 03-20-2005, 10:33 PM   #2867
InitialD's Avatar
Nervous as in twitchy? You could try a softer oil like 50 or 40wt. Set the front trackwidth to 200 mm for more stability.
For a hard rear diff, it will be better to use more caster (i.e. more clips on the front of the front upper arm).
Old 03-21-2005, 06:31 AM   #2868
Sow&Steady's Avatar
Yes, look at 3hobby.net ... I just posted a VERY good one for the G4 E-Class by D. Johnson
Current setup
Front
Droop 1
toe: out 0.5
caster: forward max
tyre: 37
one way
Track width: 199
Camber: 2
Rear
Spring std
Droop 4
toe: in 2
Tyre: 37
Camber: 4
Track width: 200
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 03-21-2005, 07:11 AM   #2869
Regional Moderator
daniz24's Avatar
try to change caster position to maximum backward
daniz24 is offline   Reply With Quote
Old 03-21-2005, 08:15 AM   #2870
MikeWz's Avatar
Send a message via AIM to MikeWz
Can somebody set me up with a picture or something of the steering servo set-up? I'm trying to figure out why my Linkeage is hitting the back fo the front upper a-arm. I can't turn left
MikeWz is offline   Reply With Quote
Old 03-21-2005, 06:29 PM   #2871
Regional Moderator
daniz24's Avatar
Yes, some people also have this problem at the first time because they use different servo. You can shave the ball cup.
Old 03-21-2005, 07:54 PM   #2872
MikeWz's Avatar
I'm using a Hitec 645. You think that would be the cause of it?
Old 03-21-2005, 08:16 PM   #2873
Motorman's Avatar
when using a hitec put the ball on the backside of the arm that came with the servo. did your servo come with the metal arm.? you may in your case need to space the servo forward. (Arm close to the bulkhead. ) Keep the linkage as straight as possible. Take the time to spacer the servo forward so the arm is close to the bulkhead. Eric Jones one of our team drivers (rd mongoose)has his set up this way
with a ko servo put the ball on the frontside.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-22-2005, 07:09 AM   #2874
MikeWz's Avatar
Motorman - It actually didn't come with a metal arm. It came with a red 4-arm set-up. Should I just use the G4 arm and put the ball on the backside?
Old 03-22-2005, 07:36 AM   #2875
Regional Moderator
daniz24's Avatar
New items from K-factory :
K1410-2 New 30mm Push Type Clutch Update Set (for K1410/K1341/K1215)
K1410-3 New 30mm Push Type Clutch Heavy Centrifugal Shoe (3)
K1410-4 New 30mm Push Type Clutch Shoe Large Plate
K1410-5 New 30mm Push Type Clutch Thinner Shoe
K1410-6 30mm Push Type Clutch Spring (Red)
K1410-7 30mm Push Type Clutch Spring (1.7mm Orange)
K1410-8 30mm Push Type Clutch Spring (1.8mm Yellow)
K1430-1 G4 New Strong Carbon Bumper Top Plate
K1439-1 G4 New Carbon Side Plate (also for K1487)
K1477 G4 Alum. Front Solid Axle Set
K1480-2 G4 New Steering System Alum. Arm (2)
K1486 G4 Conversion Set For Lola VDS Body
K1487 G4 S-class 3mm Lightweight 7075 Alum. Chassis
K1487-1 G4 S-class 3mm Lightweight 7075 Alum. Chassis (w/alum. brace)
K1488 G4 New Super Hard Universal Joint (2)
K1492 G4 S-class Speed Gear Set
K1493 G4 & V1 New Competition Low Friction Front Belt
K1494 G4 & V1 New Competition Low Friction Side Belt
K1495 G4 & V1 New Competition Low Friction Rear Belt
K1496 G4 Alum. One Piece Engine Mount
Old 03-22-2005, 08:31 PM   #2876
MikeWz's Avatar
Default Chassis
Gonna snag the "RD Logics Mongoose" steering set-up, and thinking about getting a chassis too. Should I get the 4mm or the 3mm chassis? I know the 3mm will be lighter, but will it be rigid enough?
Old 03-22-2005, 08:34 PM   #2877
Motorman's Avatar
K factory 3 mm is what is in our kit it is heavy enough we think. 4 is over kill I think given the cars inherent rigidity.
Old 03-22-2005, 08:35 PM   #2878
Motorman's Avatar
danniz most of that we already have or it is on the way. should be here any day. what is on the way is the newer belet and clutch springs in 1.7 1.8 and the solid front axle. everything else we have in stock at the warehouse.
Old 03-22-2005, 08:41 PM   #2879
Motorman's Avatar
Runaround.
nervous: go to 40's
sweeper push: soften the rear shock oil to 40. The car will transfer faster. Infact this will also reduce the nervousness of the car with the 37's on it. you could also soften the spring one color and or lay the front shock down one hole.
Old 03-22-2005, 08:44 PM   #2880
Default yard sale !
hey dennis ,waz-up! someone said your're having a yard sale .
lol ! old r/c cars
isuzuguy is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
