Old 02-23-2005, 07:10 PM   #2821
Originally posted by Motorman
zizu read my most current post on the mongoose thread. gear strip is not an issue if you get the combinations and set the clerance right.
Ok.It just seemed that many are stripping the gears. Thanks
Zizu is offline   Reply With Quote
Old 02-23-2005, 07:18 PM   #2822
Zizu... Motorman makes a good post about the gears on the Mongoose thread on page 11... Check it out as it may help as well... The key is gear mesh and to make sure you're not engaging to late with your shift point. I hope I didn't confuse you much.. lol Good luck
RC_Alan
rc_alan is offline   Reply With Quote
Old 02-25-2005, 02:13 PM   #2823
Motorman's Avatar
new steering blocks for added steering out of the same material as stock
I'm on this one. also the new flyweights out of the hard stuff. other things to. working on a document to send off this weekend
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 02-25-2005, 08:34 PM   #2824
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
It happens because of the flywheel
Walter Diaz
wad is offline   Reply With Quote
Old 02-25-2005, 08:40 PM   #2825
Motorman's Avatar
yes I know that to. but the flyweights distort. I'm gonna get both of them.
Old 02-25-2005, 08:56 PM   #2826
Default gear chart
hey waz-up? have you finished the gear ratio\roll-out chart yet!
david showed me the new pit bag its nice!
isuzuguy is offline   Reply With Quote
Old 02-26-2005, 01:20 AM   #2827
isuzuguy.. I have the G4/Mongoose gear ratio chart... Tried to upload it... Didn't work... PM me and I'll send it you. All you have to do in plug in numbers/gears you're running or want to run and the chart will give you your ratio... You can even plug in the side/brake pulleys as well... ie 18, stock 19 and even 20 and it'll give you your gear ratio. If someone know how I can upload it... It's in Mircosoft word, let me know and I'll upload for everyone.
RC_Alan
Old 02-26-2005, 09:46 PM   #2828
Quietroit's Avatar
Default setup for a tight with low grip
Motorman I have a problem of push in to the corner and coming out. I have the new steering system. This is my setup for the G4
droop Front 1/ Rear 4
toe out Front 1/ Rear Toe in 2
caster 1
Ride Height Front 5/ Rear 5
Diff lude Front 30,000/ Rear 10,000
tire shore Front 40/ Rear 35
shock oil Front 80/ Rear 80
Camber Front left 2.0/ 1.5 Rear left 3.0/2.5
Can you please help me out
Quietroit is offline   Reply With Quote
Old 02-26-2005, 10:16 PM   #2829
Motorman's Avatar
sent you a pm need more info
springs
tire brand
body
traction level of track, what do they spray with?? something nothing what?
I already see some things you need to change and I will have you check a few other things
Old 02-27-2005, 05:56 AM   #2830
Regional Moderator
daniz24's Avatar
Default Re: setup for a tight with low grip
caster 1
Try lower your shock oil and use 35 rear 37 front or 37 all round for the tires.
daniz24 is offline   Reply With Quote
Old 02-27-2005, 11:36 AM   #2831
Motorman's Avatar
yes that is exactly where I would go first. 37's all the way around and soften the shock oil 35 or 40 is a good place to start. your front end is way to hard for unprepped asphault. change front droop to 0
Old 02-27-2005, 09:27 PM   #2832
Quietroit's Avatar
Thank you Motorman
Old 03-01-2005, 01:19 AM   #2833
border r/c's Avatar
Default Jilles Groskamp will run the G4 in ...
Snowbirds winner 2005.
will race the TM G4 in the Dutch series 2005.
keep you all updated as soon the winter is over here on this side of the globe.
after the snow is gone we will make our first test.
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 03-01-2005, 04:58 AM   #2834
markp27's Avatar
Send a message via ICQ to markp27
Default Re: Jilles Groskamp will run the G4 in ...
Originally posted by border r/c
.......after the snow is gone we will make our first test.
Can you send the snow clearing machine to Nuremberg, please
markp27 is offline   Reply With Quote
Old 03-01-2005, 06:05 PM   #2835
Default Clutch Update Kit
I noticed that there is two kits available to buy. There is one with the New 30mm Push Type Clutch Shoe Large Plate, and one without this plate. What is the differance if any ? Thanks !
JoeRocket is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
