Old 02-01-2005, 06:47 PM   #2806
Regional Moderator
daniz24's Avatar
K-Factory should make this alum rear bulkhead bracket for a more durable car.
Or at least, sell them separately with the rear bulkheads (502196)
daniz24 is offline   Reply With Quote
Old 02-01-2005, 08:18 PM   #2807
coastaltony's Avatar
I will be posting a TM G-4 EVO for sale soon. Will sell as roller, or with Picco and servos. Email me.
Meucci pool cue collector
coastaltony is offline   Reply With Quote
Old 02-04-2005, 11:06 PM   #2808
daniz24... Nice looking G4's!!! Where did you get that part from or who made it for you??? I've gone through 3 myself...
RC_Alan
rc_alan is offline   Reply With Quote
Old 02-05-2005, 08:05 AM   #2809
Regional Moderator
daniz24's Avatar
RC_Alan
Hi Alan, I believe all my customers who complained and also you have a lot of spare rear bulkhead
It's made by GPM Hongkong. I expect K-Factory make this as optional parts for G4 user and also I'm looking forward for better quality than GPM.
Old 02-06-2005, 07:54 PM   #2810
daniz24... Thanks for the info...
RC_Alan
Old 02-10-2005, 08:34 PM   #2811
Dynamite's Avatar
Send a message via MSN to Dynamite
Team Magic G4 Evo
Car is roughly 5 months old, raced at club meetings and Summer Nats in Canberra last month (22nd/23rd January) only, all looks practically new apart from under belly chassis scratches but try stopping that from happening... also I noticed one front cvd is broken when I was cleaning it up.
Std K-Factory parts with car:
K1406 Front blade type anti-roll bar
K1407 Rear blade type anti-roll bar
K1408 Carbon Radio Plate
K1409 Front One-way
K1410 Push type clutch set (Centax)
K1418 Alum, hex wheel adaptor (clamp type)
K1462 front CVD Set
K1470 Alum, servo saver (Replaced with K1480 New
steering system and K1481 New steering blocks)
Parts added to car:
K1423 Light-weight Alum, One-way hub with bearing
K1424 Light-weight Alum, Two-speed housing with bearing
K1426 Alum, Radio plate support
K1427 Alum, Servo Mount
K1434 Alum, Brake leaver
K1437 Rear carbon shock tower with Alum, stiffener
K1439 Carbon side Plates
K1441 Front Upper carbon stiffener
K1443 Light-weight Vent brake disk
K1466 Hardened rear lower hinge pins
K1471 Carbon brake bracket with tensioner
K1474 Alum, middle mount
K1480 New steering system
K1481 Hard composite steering block (More Steering)
All G4 parts replaced by K-Factory gear I will send as spares, original belts are still new as I have the low friction K-Factory ones installed from new.
The only part on the car I want to keep that is in the pictures is Alum, lower spring cups (K1467).
New better Pictures:
Pic 1Pic 2Pic 3Pic 4Pic 5Pic 6Pic 7Pic 8Pic 9Pic 10 Pic 11Pic 12Pic 13Pic 14Pic 15Pic 16Pic 17
I would like $400 - 450AUD buyer to pay postage.
PM or Email me if interested make an offer even, was going to put it on evil bay, but thought I would try here first, someone here might appreciate it more.
www.racingfactory.org
Kyosho RRR Evo | Sirio Evo III STI | Ko Radio
Dynamite is offline   Reply With Quote
Old 02-11-2005, 07:08 AM   #2812
I'm selling the rolling chassis for $240.00. [email protected]
Old 02-14-2005, 05:05 AM   #2813
jaykay's Avatar
hi guys,
does somebody of you use a failsafe and when yes, which kind of do you use?
regards, jaykay
jaykay is offline   Reply With Quote
Old 02-20-2005, 01:53 AM   #2814
Originally posted by jaykay
hi guys,
regards, jaykay
I believe you can't use them with digital servo.Anyway I using futaba unit using hitec 945 servo.But Q-world micro unit failsafe should work best in G4 compact environment.
Zizu is offline   Reply With Quote
Old 02-20-2005, 01:57 AM   #2815
Sorry I mean I'm using KO failsafe using Futaba 3pk radio set
Old 02-22-2005, 12:37 AM   #2816
jaykay's Avatar
have somebody heard something from nick or tina from teammagic?
what about the new website?!?!
Old 02-22-2005, 07:21 PM   #2817
... Be very... very careful with your gear mesh... Or you'll be losing gears left and right...
RC_Alan
Hi RC_Alan.I've just got myself the s class gear set but now I'm having reservation of putting them in my car cos of the stripping gears issue.When you say be careful...does fixing it the normal way doesn't work? How did you fix it in? Thanks.
Old 02-22-2005, 07:58 PM   #2818
Motorman's Avatar
zizu read my most current post on the mongoose thread. gear strip is not an issue if you get the combinations and set the clerance right.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 02-22-2005, 08:11 PM   #2819
nickko's Avatar
Send a message via MSN to nickko
Please find the new item below. We will try to work on the alum. one, but not sure.
502196-1 G4 Back Bracket
nickko is offline   Reply With Quote
Old 02-23-2005, 07:08 PM   #2820
Zizu... The gear material is different then the stock spur gear material... I've stripped gears also, what you'll have to do is make sure that your transmission is not engaging to late. If it is and when 2nd gear jumps in, it'll be to much of a hit and your gears will strip. Loosen up your transmission so that your shift point will be a little earlier. The Gears are alittle bit smaller then stock and you'll have to use the new 2nd gear housing that comes with set. When the shift point is set correctly, you'll be in 2nd a tab bit earilier then what you would have been if you didn't switch from the stock gears, but your speed will not suffer at all and you'll be in top gear longer... Thus more speed. Now I don't know what kind of track you're racing on as you just may need to switch to the new clutch gears that comes with the S-class gears if more bottom end is what you're looking for. If top end speed is what you're looking for, adjust your shift point, check your gear mesh and you shouldn't loose your gears so soon. TM and RD Logics, with that said, should look into making the S-class gear out of the same material as stock and also make the new steering blocks for added steering out of the same material as stock... That's for another thread... You all know how long I've had the car, with all the help I've given to TM and the reader here... I still support the car, TM and RD-Logics 100% in more ways then one...
Zizu, Good luck
RC_Alan
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
