Old 11-14-2004, 10:55 AM   #2716
What is the JP-blue based on, is JP a modified version of a factory motor?....which one.
hitek is offline   Reply With Quote
Old 11-14-2004, 06:25 PM   #2717
Regional Moderator
daniz24's Avatar
The basic of the JP FX (Blue) is Novarossi NSR, but with JP's spec. Just like RB...
daniz24 is offline   Reply With Quote
Old 11-14-2004, 07:09 PM   #2718
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
nops......
the JP crakcase is slightly different.......if you try a novarossi piston/sleeve set on a JP engine you 'll burn every glowplug you put there.......
and any novarossi, rex or top is faster than jp......the fx series is simply crap.....
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 11-14-2004, 11:41 PM   #2719
InitialD's Avatar
Sure?
Not what I've seen...
Old 11-15-2004, 12:05 AM   #2720
Sow&Steady's Avatar
nops......
I have seen 3 different drivers of 3 different abilities with the JP-FX ... it is not crap. They were all 3 port engines and they easily kept up with my Rody and the NSR 5 ports.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 11-15-2004, 09:22 AM   #2721
Default aluminum servo saver
Bought the new G4 Evo, am I better off to upgrade to the K-factory servo saver and the sliding steering rail mounts or are the stock plastic ones OK. I want to build it right but on the other hand don't want option parts just for the sake of having option parts.
Old 11-15-2004, 06:12 PM   #2722
Regional Moderator
daniz24's Avatar
I'm using the K-Factory aluminum ones, but I get rid all of the dust cover for smoother movement.
Old 11-15-2004, 06:17 PM   #2723
Default steering
this steering issue has been confusing....I guess the one I have is the latest version with the new K 1481 steering. Correct me if I am wrong, but I uderstand this system does not use the original servo saver or slider system?
Old 11-18-2004, 04:41 PM   #2724
Sow&Steady's Avatar
Default BRCA 2005 Rules
If you intend to race in the BRCA Nationals next year, the 2005 Rules Amendments for 235mm, Scale Rubber and 200mm Scale Touring classes is now available at 3hobby.com for download.
Old 11-22-2004, 12:25 PM   #2725
bballer's Avatar
My original chassis is starting to crack, so I was wondering with costs in mind, should i get the 3racing 4mm chassis, kf 4mm for 35 more, or the kf 3mm one. which one will hold up, and if i get the 4mm will i notice a huge diff b/c of weight? thanks
bballer is offline   Reply With Quote
Old 11-22-2004, 01:49 PM   #2726
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
The 4mm chassis is too hard, it will make your car harded, so it will change your weight transfer.
I think that if the chassis if softer (flexible) like the 3mm, it will give you better traction , due to more weight transfer on the car.
The 4mm is good if you want to go straight with big turns.
I will stay with the 3mm one by K-factory
Walter Diaz
wad is offline   Reply With Quote
Old 11-22-2004, 01:55 PM   #2727
with the 3mm chassis, what is a good recommendation for shock oil and the shock pistons and springs, running a front one way. One track is a lot of high speed with fairlry fast corners and the other is a tight technical track.
Old 11-22-2004, 05:18 PM   #2728
Regional Moderator
daniz24's Avatar
The 3mm are not so durable comapre the 4mm one. Last time my friend broke 2 chassis in 1 race because the front side is cracked just after small hit.
Old 11-22-2004, 06:53 PM   #2729
bballer's Avatar
if i get a 4mm chassis, should i get two 3racing ones or 1 kfactory one? im not going to notice a difference as im not that experienced?
Old 11-22-2004, 07:35 PM   #2730
Regional Moderator
daniz24's Avatar
3Racing one's is heavier but cheaper...
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
