Old 11-01-2004, 08:14 AM   #2686
Regional Moderator
daniz24's Avatar
Have any of you guys experienced the front solid axle (spool)??
Because now this is more like a trend and all cars are using it, for example almost all factory drivers competed on 200mm Nitro Worlds and 1/10 EP Worlds are using them... and I'm in progress to modifying the rear solid axle into front. Will post pictures in a couple of days.
daniz24 is offline   Reply With Quote
Old 11-01-2004, 08:50 AM   #2687
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I tried spool very much with my V-One RR, with no great success. I do think it's mainly because of the Swedish track standards, VERY large, in the US the tracks are often smaller which suits spools better. I did'nt really manage to get any corner speed with the spool. More of a stop-and-away driving style.. I tried soft front suspension but then it oversteered on power.. Nah, one-way to the people!
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 11-01-2004, 01:59 PM   #2688
you can make a spool a couple of ways, using the one way, put a drill through the one way bearing and output shaft then knock a metal pin though it and epoxy glue it, the 2nd way 3-racing make an adapter to fit inside a geared front diff that locks it up, or just fill a front geared diff with a srong thick epoxy glue.
have tried one with rubber tyres, gives really good pull out of the corner but may under steer alittle going into it
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 11-01-2004, 04:32 PM   #2689
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
Default Spool
Easiest way is buy a kawahara solid rear for V1R and mount the front pulley thats it. fits straight it no mod needed. good for open track not for tight corner push too much
*Tourer**Futaba***SpeedPassion
*F1**4PX***TORO
*12th**4PX***TORO
*8th**4PX***OS Speed XZ-R
*10th**4PX***OS Speed XZ
tl2111 is offline   Reply With Quote
Old 11-01-2004, 05:03 PM   #2690
have you tried one,are the mounting holes in the same place as the front pulley, and is the pulley in line with the middle mount pulley.
i've just had a look at fitting the oneway in the back (this is for refferance only not to try), know the front pulley is mounted tight too one side and rubs on the rear bulkhead, where as the rear pulley is mounted closer to the middle. know unless they have made the solid back axle different i can't see it fitting in the front.
if i'm wrong please tell me, and i will get one ordered
Speedmerchant WGT
Old 11-01-2004, 05:37 PM   #2691
tl2111's Avatar
Trust me, it fits perfectly in it, the karahawa are different to Kyosho solid axle, u can just screw the front pulley and the out drive, pins from the rear gear diff and is cheap, i think is less then 30usd to build it
*F1**4PX***TORO
*12th**4PX***TORO
Old 11-01-2004, 07:33 PM   #2692
Regional Moderator
daniz24's Avatar
Right now, my front axle is done. I'm using the K1411 (G4 rear solid axle) and Kyosho's diff set, which you only need is the front pulley mount. For modification, just have to drill one small hole on the plastic side.
Old 11-02-2004, 12:04 AM   #2693
kidDynomite's Avatar
Jas is right, the spool will under steer a little. But after I changed my RR Evo's steering hubs (should fit G4) with the RRR hubs, the sucker turned on a dime. Through testing, use a looser than normal rear diff (5-10K oil) and softer springs, stand up rear shocks (one hole at a time) and maybe even a rear sway to keep the front inside wheel down (you'll be on the gas more throught the turns).
I really loved the spool. Took a little getting use to, but it's the easiest to handle if you want to drive harder/faster. And hard braking is a great advantage too.
I posted this a few times in the RR thread but just incase you want to try making your own spool, here's how I did it:
kidDynomite is offline   Reply With Quote
Old 11-02-2004, 12:06 AM   #2694
Let's try that again ...
Old 11-02-2004, 12:08 AM   #2695
Wow! sorry to take up space with that image. Should've posted the smaller version. Anyways, let me know if it works or not for you.
Old 11-02-2004, 04:16 AM   #2696
Regional Moderator
daniz24's Avatar
I think it's like the Serpent's oneway correct? I prefer build a new one than sacrifice my oneway. Because my friend saw Salven's oneway is broken when he locked it to solid axle on last WC.
Old 11-02-2004, 02:54 PM   #2697
kidDynomite you must have far too much time on your hands.
Speedmerchant WGT
Old 11-03-2004, 10:39 AM   #2698
Regional Moderator
daniz24's Avatar
This my rear solid axle modded to front spool.
Haven't any chance to tested it though...
Old 11-03-2004, 10:41 AM   #2699
Regional Moderator
daniz24's Avatar
Forgot the picture :
Old 11-03-2004, 10:43 AM   #2700
Regional Moderator
daniz24's Avatar
another picture :
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
