Old 10-26-2004, 09:04 PM   #2671
Default screws
is there someway to get a list of screw sizes, thoughs small one for the steering worry me i like to get extra !also i see where they have option pulleys for brake and 2 speed shaft 18 and 20 t need m
isuzuguy is offline   Reply With Quote
Old 10-26-2004, 09:46 PM   #2672
Motorman's Avatar
yes they just came out we should have them soon.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 10-27-2004, 11:43 AM   #2673
Originally posted by InitialD
Aside from the above, changing these pulleys would require changing belts also. Not so much on the side belt which can be taken up by the side belt tensioner but the rear belt needs to be different I think...
there is a rear belt tensioner available, that would sort the 18t gear
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 10-27-2004, 08:09 PM   #2674
InitialD's Avatar
What about the 20T when the belt is going to be tighter?
Old 10-27-2004, 08:16 PM   #2675
Motorman's Avatar
D
I'm just speculating because I haven't seen the gears yet but I believe they have probably tried to keep the actual diameters very close and are using a wierd tooth profile to get the tooth spread to what is needed. we have all seen that with pinion gears at times. same type of deal I figure.
Old 10-27-2004, 08:19 PM   #2676
Motorman's Avatar
look at the picture of the two gears on TM's site (the silver side ones. Note the spacing between the teeth. the 18 is wider and the 20 is narrower. Like I said I think the od is is constant.
Old 10-28-2004, 12:15 AM   #2677
Data's Avatar
won't work with belt and pulley. with pinion and spur is ok because the number of teeth in contact between the pinion and spur is 2 at most at any time, the pinion's and the spur's pitch can be off a little. with a belt on a pulley, approx. 40% of the teeth is in contact at any time, the pitch on the belt must match the pitch on the pulley. can't maintain same pitch without changing the diameter of the pulley.
Data is offline   Reply With Quote
Old 10-31-2004, 04:41 AM   #2678
Bundy_Bear's Avatar
Originally posted by FREAKAH
What was the track temp? 140 degrees F?
Here in Hawaii we usually get track temps averaging around 135F throughout the year. Tires used are usually Sorex 36R and 40R, Yokomo 138GF and 138GH, and recently the Take-Off CS-32 and CS-37.
As far as inserts go, Sorex thin firms, reg soft and HPI soft and med are regularly used.
Track temp today was up to 40 degrees at about midday
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-31-2004, 04:44 AM   #2679
Bundy_Bear's Avatar
Clutch Slippage
Guys,
Have any of you had any problems with the stock clutch slipping all the time. I pulled it apart and reset it an with 4 minutes into my next race it was slipping again?
BB
MissMooRC Racing
Old 10-31-2004, 07:22 AM   #2680
Regional Moderator
daniz24's Avatar
Are you using the standard clutch or the new clutch set?
daniz24 is offline   Reply With Quote
Old 10-31-2004, 12:00 PM   #2681
Trader Rating: 49 (100%+)
Bundy_bear
I had the same problem until I switched to the new clutch and spring. No problems after that.
rodneybarrett is offline   Reply With Quote
Old 10-31-2004, 01:51 PM   #2682
Motorman's Avatar
you need the k1410 clutch spring, weights, and shoe upgrade. the weights have brass inserts in them for more force.
http://www.rdlogics.com/store/P_353.htm
Old 10-31-2004, 11:03 PM   #2683
Nitro Tech
dino.tw's Avatar
I'm using stock clutch shoe and fly shoe. But I use new red spring. It works fine to me. I got 5th in A main in our National yesterday. (more than 50 entries)
dino.tw is offline   Reply With Quote
Old 11-01-2004, 03:18 AM   #2684
Bundy_Bear's Avatar
Originally posted by rodneybarrett
Bundy_bear
I gotta say between this an the steering system this car has been a disappointment
MissMooRC Racing
Old 11-01-2004, 04:58 AM   #2685
Bundy - sent you PM....don't give up hope.....its just like anything else that is new it just takes time to set everything up properly and you will love the G4.
peakman is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
