Old 10-08-2004, 09:27 AM   #2536
anyone ever try the schumacher fusion shocks? Also is there a place where i can buy the complete kit of shocks for mugen? I saw them on the link posted but it doesn't come with springs. Can i use my springs from the Reflex?
Thanks,
Mike
budlightnmyhand is offline   Reply With Quote
Old 10-08-2004, 11:02 AM   #2537
border r/c's Avatar
Default New TM The Border evo II G4
this what all is included in the New kit :
- TM t-shirt
- TM Cap
- Kawahara body
- New steering k1480
- New steering blocks k1481
- Extra New clutch set k1410-1
- 4mm Lightweight chassis k1479 blue
- With the new Fuel tank k1419
- Carbon side plates k1439
- Carbon Front shock tower k1440
- K-factory G4 Front universal joints k1462
- Carbon brake bracket k1438
- Carbon arm stiffener brace k1442
- Hex wheel hub blue K1418
- Low friction belts K1402-k1403
- A set of standard belts
- Alpha front bracket for alpha starter 111124
- Hard-coated alum. threaded shock
absorbers
- Teflon Pistons
- Lightweight M0.8 2-speed system (super efficient)
- Vented brake disc & brake cam bearing
- Soft belts & lightweight dust-free pulleys
- Lightweight pivot balls
- Light weight middle & 2-speed shaft
- Full high quality ball-bearings
- Low CG front & rear gear differentials
- Specially designed 5th body post
- Carbon Radio Plate
- Front one-way set
- 30mm push type clutch set
- Front adjustable anti-roll bar set (with alum. mounts)
- Rear adjustable anti-roll bar set (with alum. mounts)
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 10-08-2004, 12:07 PM   #2538
WOW..... that's alot of K Factory parts!!!
cvccsi is offline   Reply With Quote
Old 10-08-2004, 12:25 PM   #2539
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default g4
most of those parts come standard in the evo kit
RCNUT is offline   Reply With Quote
Old 10-08-2004, 12:54 PM   #2540
True... but the EVO II comes with a bit more
If this kit is selling for $260 street price that would be a steal.
Old 10-08-2004, 01:02 PM   #2541
that kit retails at 300 euros, still a bargain though
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 10-08-2004, 01:27 PM   #2542
Mike Mandio's Avatar
Originally posted by cvccsi
If this kit is selling for $260 street price that would be a steal. [/B]
At current exchange rates, it's a little over $370.
Mike Mandio is offline   Reply With Quote
Old 10-08-2004, 01:38 PM   #2543
Sorry... I should be more specific.. $260 USD. This is the price posted on the "TM's G4 to be RD Logics New Car... " thread.
Old 10-08-2004, 01:46 PM   #2544
border r/c's Avatar
Default The Border G4 EVO II
Hi guys,
This not a normal kit this is a Special Limited one made for us,
with the parts we know who are real good for this car as we already 1,5 year race this car.
and some parts are also in the normal evo.
but we just add a lot more like spare belts ,blocks and much more
just to let you know
if any question about this kit just PM
Old 10-08-2004, 01:48 PM   #2545
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I'm building the new EVO kit for a friend and I have a couple of questions.
Since the steering has been changed is it still necessary to change the servo saver spring to a harder one?
And, how does the belt tensioner mount on the the side plate? According to the instructions, it will bind and rub against the side plate?
Racing4Evo is offline   Reply With Quote
Old 10-08-2004, 05:25 PM   #2546
will the shocks from the r12 fusion fit our car?
THanks,
mike
Old 10-08-2004, 08:58 PM   #2547
Trader Rating: 74 (100%+)
Default r12 shocks
Yes Mike they will.
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 10-09-2004, 01:47 PM   #2548
I just ran my car again, I set it up a little differently and not once did i have the rear end slide out. WOW i can come flying into a turn and the baby just hooks right up to the ground!!! I put the softer springs in the front and harder in the rear, changed the rear shock position to one hole higher. Gave it a little more negative camber in the rear, little less toe and camber in the front and took out the front sway bar and put some sorex slicks on it. Whew i love this car !!!!! ride height in the front was 5mm and rear was 6mm and don't know what diff fluid i had in the back. Tires are wearing perfectly also. I'm in love with this car again except i broke the damn servo saver again Oh well. Guess i will be ordering the new parts. I'm still sticking with the sliding rails, i love it. Soo smooth when adjusted correctly.
Mike
Old 10-09-2004, 05:07 PM   #2549
Nitro Tech
dino.tw's Avatar
Originally posted by vones
Dino, try to re-locate ur antenna wire closer to the RX....the 2 original holes meant for RX carbon plates.... use 1 of it together with an antenna holder will solve the glitching.......
Thank you. I have re-located the antenna. Hope it works fine.
dino.tw is offline   Reply With Quote
Old 10-09-2004, 08:08 PM   #2550
KMac's Avatar
Default ATTENTION! New K Factory Steering Arms SUCK!!
I put the new arms on my car about a week ago and have had nothing but problems; no matter what I do the car pushes!!!
I finally put my car on a stand and cycle the steering from hard left to hard right. When I do the left suspension raises up at full lock!?!?!? WTF? So I take the arms off and compare them and lo and behold the geometry on the left is totally different than on the right!?!?!
Does anybody elses' look like this? Surely, they must, unless these are molded in a multiple cavity mold and I got a steering arm from a bad cavity.
Check this pic out:
Notice how the ball ends on the left steering arm (the one on the right in the pic) can't travel as far as on the right arm. This is what is causing the left suspension to lift!!! Also notice how much wider area "B" is than area "A", and how line "C" is tilted much more than line "D".
This SUCKS!!!!!! I can't believe anyone with the new steering arms is getting good performance.
K Factory, you owe some people some new parts!!!!!!!!
KMac is offline   Reply With Quote
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
