Old 09-22-2004, 11:59 AM   #2416
chicky03's Avatar
Send a message via AIM to chicky03
I talked to Nickko about this and he said they are coming out with 20T pulleys that would help. They do not make a 26t gear. They might if enough people ask for it though. I am pretty sure a 26/46 would be the same final drive as a TC3 at 27/50 4.44 maybe?, and the final drive for a 20t pulley at 25/46 is a 4.41. This may be wrong but I think it is correct.
Paul
chicky03 is offline   Reply With Quote
Old 09-22-2004, 12:34 PM   #2417
Blakesrc's Avatar
Send a message via AIM to Blakesrc
Default Engine Cooling/Body holes
Hey Guys,
I just finished building my g4 and painted a new body etc. It looks as if i should make a large opening in the cender of the front window to access the fuel tank, should i cut out a portion of the back and side window for cooling as well? If anyone has a picture i would appreciate it.
Thanks,
Blake
Blakesrc is offline   Reply With Quote
Old 09-22-2004, 12:54 PM   #2418
you will need holes in your body shell for cooling, the holes you make depend on where you plan on running the car, if you plan on running at big events they run rules, efra, roar ect and there are maximum sizes.
in the uk under brca rules, the front window is to be 50mm max and to be cut inbetween the window lines. we can cut the front side windows, and rear window.
its a good idea too cut quite a bit of the rear window away, but remember the more you cut away the weaker the shell will be. i would cut a round 50mm hole in the front screen directly in line with the motor heatsink
Speedmerchant WGT
Shepherd V10 Velox Idm evo 4
Shepherd V8 velox Idm evo 4
www.DHmodelsport.co.uk
jas1 is offline   Reply With Quote
Old 09-22-2004, 05:22 PM   #2419
The NTC3 used standard threads and the G4 is Metric. Already tried that one... I believe the Kyosho FW05 has the same size clutch bell as the G4... They have a 26 and a 27 tooth 2nd gear. Went to the lhs... Ultimate hobbies... No current Kyosho parts there at all... No V1-RR, V1-RRR nor FW05... I guess I'll have to order them from the Border RC... I just wish I know that they would work before I buy them... I would go with 26-47 2nd... The Mugen's and Serpents have better gearing options then we do. I can drop the same motor in my Mugen MTX 3 and it's like night and day on the top end. Other then that, my G4 handles very well.. It just needs alittle more heart... Oh, and I'm running an RB V-12 and a Nova NS3...
RC_Alan
rc_alan is offline   Reply With Quote
Old 09-22-2004, 05:36 PM   #2420
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
The Kyosho clutch is much bigger than the G4 clutch. I think it's even smaller than the Serpent.
Racing4Evo is offline   Reply With Quote
Old 09-22-2004, 05:59 PM   #2421
Trader Rating: 49 (100%+)
rc_alan:
I was inquiring about the 1st gear pinions of the Kyosho RRR and the person that was helping (on this board) had both it and the g4. He said the the smaller pinions (17t and 18t) would not fit (he had already tried). Maybe the larger ones will.
rodneybarrett is offline   Reply With Quote
Old 09-22-2004, 08:14 PM   #2422
nickko's Avatar
Send a message via MSN to nickko
2004 Last Italy Nationals
G4 was doing ok in the race.
http://www.automodellismo.net/defaul...tent=547&mnu=1
4th Mario Spiniello 139 45:14.41 15.47 G4 Ellegi STS
nickko is offline   Reply With Quote
Old 09-22-2004, 10:11 PM   #2423
Racing4Evo... I believe that the Kyosho FR-05's clutch bell is the same size as the G4's... And it has a 26 and 27 tooth 2nd gear. I found a hobby shop in SoCal that has the gears... I'll see if it fit's and if it does, I'll test it and let everyone know how things turned out...
RC_Alan
Old 09-22-2004, 10:38 PM   #2424
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
HEY ,rc alan long time, how are things impalabob here you what im going through with this fla. wheather ,im still racing though won the a -main at our lhs best lap time 14.9 with serpent 710 .an the guy lookin more punch see if the serpent yellow shoe fits if it does ,man u better watch out thats what i run . hey alan in the main i had to compete with 2 fwo5s they couldn,t catch me .im running the picco xp12r modified .
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-23-2004, 04:37 AM   #2425
Trader Rating: 21 (96%+)
Send a message via AIM to RCNUT
Default r/c alan
Alan,
I have the g4 clutchbell and the fw-05r clutch bell gears. I will check it tonight and see if they fit and let you know.
RCNUT is offline   Reply With Quote
Old 09-23-2004, 08:23 AM   #2426
Thanks RCNUT... Good looking out for the G4 drivers..
RC_Alan
Old 09-23-2004, 08:35 AM   #2427
Default Re: r/c alan
Originally posted by RCNUT
Alan,
The clutch bell for FW-05R is much bigger than the G4. I don't think it is interchangable.
cvccsi is offline   Reply With Quote
Old 09-23-2004, 01:33 PM   #2428
Racing4Evo's Avatar
RC_Alan
The G4's clutch bell is a lot smaller than the Kyosho. All kyosho clutches are the same except for different diameter flywheels. I am in So Cal as well. Are you going to race the RD Logic race at Revelation Raceway?
Old 09-23-2004, 04:31 PM   #2429
Racing4Evo... I was going to run in that race, but I'm still breaking in a new piston and sleeve that I just bought Tuesday... I'll be there in the afternoon on Saturday to help a few of my friends that are racing ... If I'm not mistaken, the Kyosho use's the same gear mesh/pitch as the G4 .8... Also they run the same gear ratio numbers as well. Check out this link and if you have seen the G4 clutch bell, you'll see why I think the FW05 clutch bell gears will work...
http://shop.the-border.nl/customer/p...cat=494&page=2
And
http://shop.the-border.nl/customer/p...cat=404&page=8
Even though the G4's clutch bell might be a tad bit smaller, the gears are the same size... My Mugen gears fit my G4, but the gears are larger... Waiting for RCNUT's findings to see if my idea if correct. Man, if I'm correct, what a big speed boost that'll be for the G4 and so many more gearing options.. Anyone that has both cars should check and see if they'll fit... I know that's a long shot.. Someone owning a G4 and FW05... lol
RC_Alan
Old 09-23-2004, 04:40 PM   #2430
And
RC_Alan
I own both cars. I will double check tonight too.
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
