Old 09-17-2004, 01:10 AM   #2371
Originally posted by nickko
Tooned G4
You should check the steering parts, instead of belt parts. If they contact, the steering parts will wear out first, not the belt.
NO , the belt is made from a softer material and thats why it has lost its teeth. The ball cup is solid with no marks.
I use the low friction belts too.
Do you all use the top hole on the servo arm ?
I find it strange that mine rubs and others dont.
I have to run the car with unequal turnbuckle lengths to avoid the new steering from riding under the belt.i then adjust the trim to compensate.
Tooned G4 is offline   Reply With Quote
Old 09-17-2004, 01:17 AM   #2372
Originally posted by Project D
So basicly u guys think the 710 run better and has less problem than the g4?
I think it is just a case of `the grass is allways greener` whenever a problem occurs !! thats all.
Old 09-17-2004, 01:24 AM   #2373
Project D's Avatar
still need an answer
Project D is offline   Reply With Quote
Old 09-17-2004, 03:06 AM   #2374
Mr. Shims's Avatar
g4'S STILL BETTER
its still NOT enough for me to get a 710 which chews up gears...
(TYPO error on the first one)
Mr. Shims is offline   Reply With Quote
Old 09-17-2004, 06:01 AM   #2375
Default Shocks
Are there any externally adjustable shocks made for 1/10 cars? Like you can change the dampening rate with an external adjuster instead of changing the wt of the oil?
Also the stock shocks on this car suck. Which shocks can i upgrade to?
Thanks,
Mike
budlightnmyhand is offline   Reply With Quote
Old 09-17-2004, 08:33 AM   #2376
The shocks on the G4 are no worst then what's on the Mugen which I have or any other 1/10 scale car on the market for that matter... The only issue with the shocks are the bladders.... A simple $2.50 upgrade can fix that. I'm sure if we went to every other nitro companies threads here, I'm sure you'll find pros and cons with those cars as well.. I know for a fact that Serpent, OFNA, HPI, Team Assoc, Mugen, Kyosho and Yokomo have issue's with there cars... If not... You would have threads or posts of happy racers everywhere saying that there cars are all dialed.. Nothing breaks... No adjustments needed... No upgrades needed and everyone won there races in the A-main in every race... That's just not the case... There no perfect car out of the box.. Every car has to be beefed up and bullet proofed to some degree. TM addressed the issues with this car... While if may have taken longer then it should have, I'm happy that the two main issue's were corrected, that being the fuel tank and the steering system. The G4 is more durable then most and can race with be best of them any day of the week... More support would be great... Hint Nickko... but over all the G4 is a great car to drive and a good investment for the money... .02 Not flaming anyone's feelings or thoughts, but just addressing the facts...
RC_Alan
rc_alan is offline   Reply With Quote
Old 09-17-2004, 10:12 AM   #2377
Regional Moderator
daniz24's Avatar
You can try Yokomo SD shocks with SS shock body :
daniz24 is offline   Reply With Quote
Old 09-17-2004, 10:38 AM   #2378
where can i get those shock bodies and can i use the springs i have from my g4?
Mike
Old 09-17-2004, 11:51 AM   #2379
XTREMERCHOBBIES's Avatar
daniz24: nice looking car!!! what springs are you using?? is that the 3racing diff case??? Mr. Shims and i just installed the Mugen Seiki springs on our G4... he used the white ones which had a spring rate of 1.9 and i'm using the grey ones with a spring rate of 1.8 for the fronts... wish us luck!!! cant wait to get the new steering system we ordered... i think its the only thing missing to dial up our car. as for the s710... well it is a good car but for the price i would still go for the G4... remember that the g4 lapped the s710 4 times in the copa portugal 2004 last july by TM driver hugo miguel. and he was using the old steering system then. guess its also how well your skills are at the track. happy racing all
XTREMERCHOBBIES is offline   Reply With Quote
Old 09-17-2004, 07:32 PM   #2380
Regional Moderator
daniz24's Avatar
Mike
Since I also have Yokomo EP, I just switched the shock but you need the SS shock body (longer) to fit in to your G4. The spring is Purple spring from TM spring set (502143)
Old 09-17-2004, 07:36 PM   #2381
Regional Moderator
daniz24's Avatar
The spring is TM Purple spring. And yes, that's the 3Racing diff case for Kyosho Evo. But I change the gear diff to Kyosho's gear diff too for perfect smoothness.
This is also TM Green spring on the Yokomo shocks :
Old 09-17-2004, 08:27 PM   #2382
budlightnmyhand
S710 Shocks dampening are adjustible from the outside, but I am not sure if they are a easy swap to fit on a G4. Would be a good thing to look into though.
JoeRocket is offline   Reply With Quote
Old 09-18-2004, 01:35 AM   #2383
Can anyone tell me what effect changing the shims on the upper front wishbone does to the handling. Is this the roll centre adjust or castor ?
Old 09-18-2004, 02:09 AM   #2384
muppet racing's Avatar
if anyones interested heres a link to a uk website, with some videos you can download:
http://www.3hobby.com/modules.php?na...download&cid=6
you need to register to download them, but its free.in the BRCA 1:10 rubber A-main, race a G4 took tq and the win! (national race series on rubber tyres)
theres also some other videos of foam races.
tooned: the plastic shims adjust the castor angle, which basically changes how much tyre is in contact when you apply steering lock.
to see this, take all the shims off, put the car on a flat board(with tyres on!) put the steering on full lock, look level with the front tyre, and move the top wishbone forwards and backwards. this should show how the castor works!
hope it helps.
muppet racing is offline   Reply With Quote
Old 09-18-2004, 04:55 AM   #2385
What would be a good car setup for me to start with on a bumpy track thats unprepared with sorex medium 24mm slicks all the way around.
Thanks,
Mike
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
