Old 07-02-2004, 12:58 PM   #2041
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by pimpedaccord
For smaller track, run taller spurs and smaller pinions. And vice versa for larger tracks.
I'm not sure, but I think the stock 1st pinion is 21t? I run at a large track with 21/46, 25/50.
When you change your gearing, just try to keep the spurs and pinions proportionate to eachother (no big splits)...
they should equal example 21/46 = 67
Old 07-02-2004, 03:37 PM   #2042
our club track is small,
and i run 19/48 and 21/47
dieter
4racer is offline   Reply With Quote
Old 07-03-2004, 07:20 AM   #2043
Well guys i'm almost done putting my car back together with all my new hop ups on it. Man that steering is so smooth again!! It will probably loosen up within the first few tanks though. Did anyone else have a problem with the the tank hitting the chassis on the bottom and not allowing it to go all the way onto the posts that hold the tank. I got it to fit but man its tight.
Also i took out the rear sway bars. I think this will give me a little better traction in the back.
Mike
budlightnmyhand is offline   Reply With Quote
Old 07-03-2004, 01:15 PM   #2044
Damn, didn't know how much of a difference a plug could make. Took me about a whole to minutes for me to adjust my motor to new fuel, new air filter, and new glow plug. Before i used to have to adjust it every tank and sometimes in between tanks because it would never stay running period. I never had to adjust it after setting it up with the new plug and adjusting everything just one time!!!!! I'm glad i got a new glow plug.
Mike
Old 07-03-2004, 02:20 PM   #2045
Trader Rating: 49 (100%+)
bud...,
Yes, putting the new 75cc tank on the old chassis requires a little dremel work to not rub. So much for a direct replacement.
rodneybarrett is offline   Reply With Quote
Old 07-03-2004, 03:14 PM   #2046
Aggdaddy's Avatar
Mike
If you have removed the engine shim, that alone probably made all the difference.
Aggdaddy is offline   Reply With Quote
Old 07-04-2004, 04:23 PM   #2047
nope i left the shim in there. Just put a new plug and put on the K&N air filter. I know the K&N air filter isn't supposed to be that good but i like it.
Mike
Old 07-04-2004, 05:08 PM   #2048
Aggdaddy's Avatar
Cool. Standard plugs don't normally make that much of a difference to me. As long as my engine runs, I'm ok
Old 07-04-2004, 05:47 PM   #2049
rcracer14's Avatar
Send a message via AIM to rcracer14
Can anyone give me a set up that will make the rear hook up more? I just can't come out of a turn without the car spinning out.
rcracer14 is offline   Reply With Quote
Old 07-04-2004, 07:15 PM   #2050
Regional Moderator
daniz24's Avatar
How about thinner diff oil, less rear downstop or more rear toe-in.
daniz24 is offline   Reply With Quote
Old 07-04-2004, 07:20 PM   #2051
Regional Moderator
daniz24's Avatar
The stock pinion are 20T and 24T...
That's impossible, maybe what you meant is 21/50 on 1st gear and 25/46 on the 2nd gear.....
Old 07-04-2004, 07:37 PM   #2052
rcracer14's Avatar
I have the stock diff oil in it right now and It seems pretty thin, is there some springs I should try or different shock oil? Also, I have already a good amount of toe-in.
Old 07-04-2004, 08:57 PM   #2053
try lighter oil in you rear shocks, if you are spinning out you need to make your rear softer.
brooklynrc is offline   Reply With Quote
Old 07-04-2004, 09:00 PM   #2054
Trader Rating: 52 (100%+)
hey guys
is the stock gearing to tall for a 100 x 50 track
Mo
Mo Denton is offline   Reply With Quote
Old 07-04-2004, 09:42 PM   #2055
Super Moderator
Marcos.J's Avatar
Originally posted by 1fastguy1
hey guys
Mo
probably , that sounds like an electric track.
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
