Old 08-02-2003, 08:02 PM   #166
Trader Rating: 49 (100%+)
OK, I have found my first dislike of the G4. The 1st gear ratio is with stock gears is 6.42 which is waaaay too big for the little tracks where run on around here. One of the local tracks is a bunch of sharp turns and you need to be able to accelerate hard to get to the next turn. The best I will be able to with a 19t pinion and 52t spur is 6.89.
I am in need of around 7.50 1st gear ratio. Are there any aftermarket pulleys to help get this type of 1st gear ratio?
rodneybarrett is offline   Reply With Quote
Old 08-02-2003, 11:54 PM   #167
border r/c's Avatar
Wink gearing
we hat same we changed to 19t 52t thats what you need
http://www.the-border.com
Europe's largest 1/8 scale 1/10 rc car warehouse.
3Racing-Ride-BRP-Team Orion-XRAY-HUDY-Serpent-Kyosho-Lrp-Speed Passion-MR33-JG-and many more
border r/c is offline   Reply With Quote
Old 08-03-2003, 09:08 PM   #168
InitialD's Avatar
I have mentioned earlier that this car will not be as good as a small technical track car when compared to the Reflex NT because of the stock and available gearing...
I don't know if this would be of much help to you but you could use the 54T 1st gear spur of an NTC3 (yes, NTC3 from AE ). The 54T spur will be a direct fit to the one way 1st gear hub carrier and they mesh correctly with the existing pinions. This is what the local guys here are using and they seemed to be pretty satisfied with it. Well, I don't think it'll give you anywhere the 7.5 1st gear ratio but you'll get somewhere at 7.18 Also, using smaller tires will help. Hope that helps...
Old 08-03-2003, 09:21 PM   #169
InitialD:
Thanks for the advice. I may give that a shot.
Do I need to change any other spurs/pinions? It would seem that the 54T spur will make things somewhat out of sync using the other stock spurs/pinions.
Also, anyone know where I can get the 52T spur and 19T pinion for this car and get it delivery by Friday? US preferably, but I'm not opposed to any other place.
Old 08-03-2003, 09:57 PM   #170
InitialD's Avatar
I don't think you need to change other things... The meshings should be correct I'm told. I'm sure one of your racing buddies run an NTC3 and will have the 54T spur available. If you're uncertain, you can quickly mount the spur onto the G4 one way hub for the 1st gear spur and check it out. I would think the AE 54T spur is pretty cheap anyways.
Check Trinity's site... I think they list the 52T spur and 19T pinion.
Old 08-04-2003, 09:05 PM   #171
InitialD:
Found a 54T AE spur today. It screws onto the one way bearing where the G4 has half-moon like grooves that it fits into. I don't see how it would work.
Please find out from you buddies exactly what's invovled. I would love to try it this weekend and a big race we are having.
thanks.
Old 08-04-2003, 09:20 PM   #172
The pitch is totally different on AE gears.
Gemballa750 is offline   Reply With Quote
Old 08-05-2003, 08:29 AM   #173
I believe they are the same pitch. I was able to put a NTC3 pinion on one of my spurs and the mesh was fine.
No one has really come out and said it but I guess associated's gear are .8 as well.
Old 08-05-2003, 02:24 PM   #174
The unit of measurment is different, the AE gears are a 32 pitch. If they mesh together correctly then go for it though.
Old 08-05-2003, 09:38 PM   #175
InitialD's Avatar
Looks like they are I'll check with the guys on how they did the mod. But I thought the guy mentioned that he used the stock G4 one way hub. But then again he was fiddling with the MTX-3 hub too...
Old 08-06-2003, 08:45 AM   #176
Regional Moderator
Darkseid's Avatar
Is there a downloadable Instruction Manual or exploded diagram(.pdf) for the car anywhere out there. I went to Trinity's site, but they didn't have one.
I'm thinking of replacing my Reflex with this car over the off season, and I would like to get a closer look at it if possible.
Darkseid
TLR 22...Tamiya F104...
Old 08-07-2003, 05:31 PM   #177
tony montana's Avatar
Trader Rating: 66 (100%+)
How is the g4? Is it very durable? Im thinking about getting back into touring and want a top notch car. Also what engines do you recomemend? Is the mt12 at the top?
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 08-12-2003, 08:20 AM   #178
Trader Rating: 74 (100%+)
Default Durability
Tony,
The G4 is one of the nicest kits your are going to buy. I have one, just recently added some K factory parts, and the car runs awesome. It is probbably the most innovative kit to date, but who knows what's around the corner.
The deciding factor is parts. Are you ready to not race, or carry a spare few parts. Possibly your LHS will not stock Trinity G4 parts yet. So if you are able to handle this, than the G4 would be a excellent choice.....
Good Luck!
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 08-18-2003, 08:04 AM   #179
hey guys I ran my g4 in cincinatti this weekend and I have to say that once you find the tire combination you like the car is awesome to drive. I only gualified in the b main, which is ok because I was trying to figure out some things on the car and we only got 2 qualifiers in, and I also arrived at the track late so I didn't get to practice and try set ups. I ended up useing 40's all around and the car was very good, I ended up qualifying 1st in the b main and was basically walking away with it when I got flipped over by a backmarker and the marshal wasn't paying attention and I sat for about 20 seconds on my lid until it flammed out, and that was that. All things considered, I feel that this car performs excelently and I highly recomend it. We will see how well trinity backs it up with parts, it would be a shame to let such a good car sit on the shelf for lack of spare parts.
mrodney is offline   Reply With Quote
Old 08-18-2003, 08:23 AM   #180
border r/c's Avatar
Default Parts in stock
just type the part nr in search and you find it in our shop
cya..
Lipo Optimized Touring car: Losi JRXS Type R or Team Magic E4? cpatel529 Electric On-Road 9 03-15-2008 09:29 PM
Team Magic G4 / Trinity G4 For Sale JohnMontoya R/C Items: For Sale/Trade 0 10-12-2004 01:19 AM
Trinity Team Magic G4 FS/FT Scrad R/C Items: For Sale/Trade 12 10-07-2004 09:38 PM
Trinity Team Magic G4 E-Class RCNitroDude999 R/C Items: For Sale/Trade 0 08-30-2004 04:46 PM
Trinity Team Magic G4 PRO E-Class NEW! vulso R/C Items: For Sale/Trade 1 09-21-2003 07:49 AM
