Trinity G4 - Team Magic G4 E-Type
#1726
Re: this is funny!!!!!!!!!!
Originally posted by Vr6vroom
AFM, you should be like Nostradomus, if you were to read the last line in the quote you will see what I mean.!!
AFM
#1727
clutch nut
Guys, I have had a load of problems with my car today
Most of them I can fix except for one. My clutch nut won't stay in one place. It is a new K-factory clutch nut that purchased to replace my old one that I broke. Everytime I set the cluctch and drive it, I may get like seven laps or so before it tightens all the way down on the spring by itself. Then it won't accelerate, mainly because the clutch shoe can't engage. I have tried thread lock several times today and last resort was pipe tape (tape that plumbers use to locktite lead pipes) and that lasted a little longer but it still tightens down on the clutch spring on its own.
Has anybody had this same problem?
#1728
clutch nut
i had a similar problem with a 1/8 serpent once, and spoke to a team driver about it, he told me too get a good size pair of pliers put them round the threads where the clutch nut goes, put some pressure on and chew the threads up slightly, don't go mad, i did this and never had the problem again.
#1729
Re: clutch nut
#1730
First outing
Well here we go again. I ran the new Evo this weekend, and encountered a couple of things. The car inherently pushes from the kit settings, changed a few thing around, got a little more steering back, but in the struggle I man aged to bust a frt hub. Right now, lhs' dont stock G4 stuff, so my time was down. I ordered the GPM alloy frt and rear hubs, so this would not happen again.
Second, my 2 sp would not shift, according to the manual. I had to loosen the screws quite a bit before it shifted in a timely manor.
Third, with the K Fact belt, the drivetrain is amazing. I cannot beleive how smooth it is.
Last, the Arrows tires supplied in the kit are awesome, I would recommend everyone check them out. Call Brooklyn Hobbies for your needs.
I did not experience any steering binding issues as for now.
I am going to try lighter oil/spring combo. I also picked up the alloy servo mount/trans holder, my frt bulkhead loosened up after a couple of tanks. With the aluminum mount this should not happen, along with the frt layshaft mount. I will keep you all posted.
#1731
This car sucks. So i'm asking which car is better, the kyosho vone rr evo or the mugen mtx3.
#1732
Well you should probably post a new thread and ask your question.
#1733
hello g4 driver,
have anyone a good solid axle setup for me, the grip on the track is good, and the track is bumpy
dieter
dieter
#1734
The MTX-3 is an easy car to work with. Setup out of the box is awesome. The car handles like it's on rails. The MTX-3 Prospec is the latest version.
Good luck
#1735
Reposition on Antenna
Hi guys,
I have looked through the previous post and can't find any pictures or techniques on how to mount the antenna using the K-factory transporder mount, as anyone got pictures of it.
Sami
Sami
#1736
When is the new RRR coming out? Also i saw the prospect kit. Will i need to buy anything else besides that or are there upgrades i still need to get just like the ones you NEED to get with this fricken G4.
Mike
Mike
#1737
"RRR" not sure yet. It depends some people run stock Mugen MTx-3 all the time. I'd get the MTX-3 Prospec it's hopped already. It's limited to only a 1000 pcs.
Well guys here's my G4 up for sale..............................
http://www.rctech.net/forum/showthre...565#post895565
#1738
#1739
Thanks for the reply,
Does anyone have a better side view of the positioning? because I can't seem to mount it thats all using the original reciever mount screws.
Sami
Sami
#1740
