Old 05-10-2003, 01:55 AM   #1
MTX-3 Adjusting Turning Circle?
I am currently running a MTX-3 on a tight small track and find they I don't have enough steering?
Here is what I am currently running.
- Ackerman A for Servo Saver
- Front Camber -2
- Rear Camber -2
- Front Toe -0.5
- Rear Toe +2
- Rear Right Height : 5mm
- Front Right Height: 4mm
Do I have to adjust any of the above or is all about the servo?
Thanks for your help
Sami
ttektek is offline   Reply With Quote
Old 05-10-2003, 02:19 AM   #2
FREAKAH's Avatar
I also run on a fairly small tight track and I find that I have more than enough steering. In fact, I had to go with a stiffer front spring.
I'm running the stock setup wih the following changes:
Grey(stiffer) front springs
Front diff with 10,000 oil
Rear diff with 5000 oil
"C" roll center blocks
Long rear camber links
0.5 deg. rear camber
BTW, i'm using rubber tires(Sorex 40R).
Check your servo saver spring tension or your up-stop setting. The servo saver, if set loose, may "give" not allowing enough steering throw. The up-stop setting, if set too much, may not allow full suspension compression thus reducing steering.
A High idle/neutral throttle or a clutch that engages too early can reduce steering in tight turns also.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-10-2003, 02:27 AM   #3
Im2lazy's Avatar
You could increase the rear uptravel so that the car gets more steering, or if you want, swings around... Or you could make the front diff oil lighter so that it turns in faster... or thicker rear diff oil to make it rotate more out of a turn....
I can only give general advice.
Im2lazy is offline   Reply With Quote
Old 05-10-2003, 02:34 AM   #4
FREAKAH's Avatar
We need more info on your setup.
Second-Hand Racing
RACE WORLD HAWAII
Old 05-10-2003, 02:40 AM   #5
Im2lazy's Avatar
And on where you need the steering to improve most... in or out of corners or just plain everywhere!
Grey springs! wow Freekah! Like I told you my MTX2 is running HPI electric springs ... Two totally different beasts I guess
Old 05-10-2003, 05:16 AM   #6
What another information do you need?
I need more steering exiting the corners with a one-way diff, so I can't add any oil to it. I am
-using stock diff on the rear,
-and using the stock shocks (blue).
-Also got the shocks mounted on the 2nd from the bottom
- Running foam tires:, 40F, 37R at 18 Celius(33 F).
What happens when I hit a hairpin is that car seems to go very wide out the corner even if I apex properly.
Please Help
Sami
Old 05-10-2003, 05:22 AM   #7
FREAKAH's Avatar
Reduce front droop
Increase caster
Reduce rear toe-in
Thicker rear shock oil and/or stiffer rear springs
All those help increase on power steering. Try them one at a time in that order.
Second-Hand Racing
RACE WORLD HAWAII
Old 05-12-2003, 10:02 PM   #8
puma1824's Avatar
Send a message via AIM to puma1824
Freakah,
What's your rid height and droop?
Still run rubbers? I would still love a great rubber setup.
Still running 10k front and 5k rear? How about shock wt.? Front and rear link positions?
Thanks,
Puma
puma1824 is offline   Reply With Quote
Old 05-12-2003, 10:40 PM   #9
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Default Re: MTX-3 Adjusting Turning Circle?
- Front Camber -2
- Rear Camber -2
- Front Toe -0.5
- Rear Toe +2
Sami
Reduce the front width of the car to about 197mm - this will fix your problem
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-12-2003, 10:42 PM   #10
Michael_T's Avatar
Forgot to mention, your front sway bar can increase/decrease the turning circle of the car. I suggest leaving this flat (softest).
Old 05-13-2003, 01:32 PM   #11
i switched to 30k rear diff oil to get more steering helps alot
next if i need more i will probably try the stiffer rear sway-bar
you could also try a little less rear toe in but i like to run 2-3 also
jason102276 is offline   Reply With Quote
Old 05-13-2003, 01:32 PM   #12
im going to try taking the front to 197mm also sounds like a good idea
Winners Circle RC gas hobby shop, are they the cheapest??? kurtcash Nitro On-Road 8 01-21-2008 07:30 PM
Adjusting Centax on PRP XR/8 Darthswan Nitro On-Road 9 07-25-2005 06:06 PM
Circle Track Glides powerglides Other Items: For Sale/Trade or Wanted to Buy 1 05-11-2004 06:36 PM
Circle Track Glides powerglides R/C Items: For Sale/Trade 0 05-08-2004 01:17 PM
Adjusting a diff hicheef Rookie Zone 5 01-15-2003 09:59 PM
