Front belt stripping ...
#17
I would think that overdrive could effect belt wear and as mentioned any hits the car takes as well as belt slop or lack of tension or too much tension.
#18
Belt up grade is takeing the rear pulley and have it milled to fit the front, run a wider belt, I think? I know its not available, it must be custom made. Other wise I would have 1. I run a 7 mm split similar issues.
#25
recommend from serpent the 16 tooth alluminum pully they fit on all the cars will cut down on broken belts
#26
Stripping belts
JFCJ, Im running a 6mm split 68 front and 74 rear...
#27
