Old 05-06-2003, 09:59 PM   #1
Durge's Avatar
Default V-one-S Servos
Guys, i have just purchased a v-one-s and obviously need servos. If i just get some standard ball bearing types will these be adequate for racing or does it require pretty powerful servos?
Also, with the green oil supplied in the kit, is this adequate for the diff or does it have other purposes? I have a very small amount of Mugen stuff left from older cars which is probably off by now, but not enough to fill both diffs? Any suggestions...
Thanx
Duuurge
Durge is offline   Reply With Quote
Old 05-06-2003, 10:09 PM   #2
VoneRkid's Avatar
Default Re: V-one-S Servos
Thanx
Duuurge
It depends on what brand of radio gear that you are running but you don't need powerful servos you can use standard servos & you can buy the ball bearing for your hobby shop and put them in your self. That what I did to my servos I am running JR 577 servos.
Damo
VoneRkid is offline   Reply With Quote
Old 05-07-2003, 12:29 AM   #3
Team_Akina_1's Avatar
Send a message via AIM to Team_Akina_1
To begin with, you can use standard servos, but it will be good to upgrade the steering servo later on, at least have them all in metal gear. I sugguest you go out and buy brand name shock and diff oils, instead of using something that is very old or your have no idea what weight it is.
Team_Akina_1 is offline   Reply With Quote
Old 05-07-2003, 03:30 AM   #4
Send a message via ICQ to V-One S
the oil supplied with the car is 40Wt shock oil
it is good for starters, a lot of people then just upgrade to 50wt in the rear later on, but im still running stock.
the diffs do not have oil, but the manual says use either grease or oil.
oil is better cause u can set the diff consistently after each rebuild.
but im still using grease.
diff oil y pay 20$ for 50ml?
V-One S is offline   Reply With Quote
Old 05-07-2003, 04:15 AM   #5
sausage_link's Avatar
Send a message via ICQ to sausage_link
hehe $11 for 50 ml
sausage_link is offline   Reply With Quote
Old 05-07-2003, 04:17 AM   #6
secret supplier?
Old 05-07-2003, 04:25 AM   #7
no
just a hobby shop :P
Old 05-07-2003, 04:35 AM   #8
damn u
mine ranges from 17$ upto 25$
bloody ripoff,
i might start ordering off stuart or the secret supplier.
Old 05-07-2003, 05:42 AM   #9
Im2lazy's Avatar
Thanx
Duuurge
I'd get the best servos you can get. The torque for the steering servo should be rated around 80 oz/in(at 6V) and the throttle only needs around 60. The speed should be around .15 or lower, but not too fast.
That is just what I think is around ideal for a touring car.
Im2lazy is offline   Reply With Quote
FS- High end radio gear, KO Helios, KO servos, JR servos, Spektrum cdelong R/C Items: For Sale/Trade 16 11-01-2007 09:33 PM
Servos Craig1 Australia For Sale/Trade 0 02-20-2007 04:20 AM
LOT OF SERVOS; Futaba,Traxxas & mini servos! nitro468 R/C Items: For Sale/Trade 10 03-27-2006 07:19 PM
jr,kopropo,futaba servos (high speed/trorque sedan servos) lazyboy R/C Items: Wanted to Buy 6 06-06-2005 11:27 AM
NTC 3 Servos martymarine Nitro On-Road 1 09-03-2003 10:06 PM
