Old 05-06-2003, 06:40 PM   #1
Default what is the correct way to set droop
can some one help me on the right way to set droop
HYPER is offline   Reply With Quote
Old 05-06-2003, 07:02 PM   #2
popsracer's Avatar
HYPER;
There are several different ways to set suspension Droop, but i'll explain what I feel is the easiest and most accurate method.
If your Chassis has Droop Screws the job is much easier. If not, you will need to adjust Shock Length.
1) Set EVERYTHING else first. Ride Height, Camber, Toe, etc.
2) Using a Ride Height gauge, push the gauge under the Center of one end of the chassis until the Tire(s) just clear your set-up surface (preferably a flat set-up board).
Note the reading. The difference between this measurement and the Ride Height is the actual Droop.
(I.E: Ride Height = 5mm, the Second measurement was 9mm. So 9mm-5mm=4mm Droop)
3) Adjust the Droop Screws/Shock Length so each tire is equal distance from the set-up surface. A strip of paper under each tire works good for this.
Clear as Mud!
popsracer is offline   Reply With Quote
Old 05-06-2003, 09:26 PM   #3
Default thx pops
thx
Old 05-06-2003, 10:51 PM   #4
THeGame's Avatar
Send a message via AIM to THeGame
Check the team losi Site the have Picture...
THeGame is offline   Reply With Quote
Old 05-07-2003, 02:17 PM   #5
GTMilenko's Avatar
I'VE been trying to get hold of you, email me!
GTMilenko is offline   Reply With Quote
Old 05-08-2003, 03:06 AM   #6
GTMilenko's Avatar
sorry bad mannors i've mine , i ment email me please,
Old 05-09-2003, 10:06 PM   #7
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Default Question Pops
I do set my droop after everything else is set. But I see some guys taking their sway bars off and shocks off the arms to set the droop. Is that typical? Thanks in advance.
picco007 is offline   Reply With Quote
Old 05-10-2003, 12:00 PM   #8
fraz's Avatar
Send a message via AIM to fraz
To set droop properly you do it with shocks and swaybars off. Once you have set the droop, connect the swaybar on one side and then see where the link meets up with the connection on the other side. Make sure they match. After you adjust the tweak out of your swaybar and connect it, recheck your droop. If it has changed, you still have a tweak in your swaybar. Repeat the above until the droop is the same with swaybars on or off. Another thing to mention is that if your shock length is shorter than the travel (droop), be abolutely certain that they are the same length or you will also have tweak issues.
I have heard many methods of setting droop but if you don't do this you are neglecting something in your car that can lead to long crumby racedays. There are some other tweak issues to be aware of but I've got to jet. Hope this helps.
fraz is offline   Reply With Quote
Old 05-10-2003, 09:24 PM   #9
popsracer's Avatar
picco007;
I have not seen anyone remove a swaybar for setting Droop and It is not really nessesary to remove the Shocks, but doing so will remove the influence of the shocks and give you a more accurate Droop reading. (your choice, I don't)
For setting "Tweak" the Swaybars should be removed (at least the "Bent" wire type should). It is also recommended to check for a "warped" Swaybar as 'fraz' has suggested.
Good luck and hope we all helped some.
Old 05-12-2003, 10:03 PM   #10
Hey Pops
How come the NTC3 instructions have you set the droop before you even finish assembling the car?
Sydewynder is offline   Reply With Quote
Old 05-13-2003, 10:49 AM   #11
popsracer's Avatar
Originally posted by Sydewynder
Hey Pops
The NTC3 Manual uses the "Block" method of setting Droop. In the assembly of the Car this is a good time to do it as there are no other influences on the setting (until you install the Shocks).
I've never seen anyone remove their Shocks nor have I done it myself when Checking/Setting Droop on an Assembled Car. Since Ride Height effects Droop, why not set Droop with the Shocks installed.
If you use the Ride Height Gauge method, your Droop setting will be VERY accurate and it's fast and easy to do this way.
Old 05-13-2003, 11:49 AM   #12
Francis M.'s Avatar
pops is right on with reading or measuring
drood this is especially important when
running foam tires due to tire wear. so
you might have to readjust your droop
as the tire wears down.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Hudy droop guage, ae droop guage, ae ride height guage Midnight R/C Items: For Sale/Trade 7 09-02-2008 09:43 AM
Correct Droop Setting...Help! Terry M Electric On-Road 15 04-26-2008 12:20 AM
what is the correct way to set up a car on carpet like roll center/droop tc3 racer sc Electric On-Road 8 10-11-2006 05:27 PM
setting droop on droop blocks mrgsr Nitro On-Road 3 01-08-2006 07:01 PM
Differences between the XXX and the XXX B2(idk if that is the correct name) Switch Blade Electric Off-Road 3 04-07-2004 08:18 PM
