Old 05-05-2003, 04:15 PM   #1
Default Tuned Pipe for SS
I have RS4 3 SS. I just finished building it, but haven't run it. For a first step for performance upgrade, I'm thinking about getting a NEW Tuned Pipe. I have two to choose from.
RB X12 Tuned Pipe
and
Novarossi high speed black pipe #51603
Which one should i get???
Oh yeah, the engine is .12SS which is made by OS. It has side exhaust and mounted on RIGHT side of the car. Then there is another question rise... both pipes are designed for LEFT engine mount. which means the pressure tube has to be mounted on the bottom side. Will this hurt the performance in anyway??? Thank you in advance.
tjrcs is offline   Reply With Quote
Old 05-05-2003, 04:32 PM   #2
rod_b's Avatar
Send a message via AIM to rod_b
They will scrape unless you mount the pipe kinda high off the ground. If you can, get the RDLogics pipe for right-side engines instead.
rod_b is offline   Reply With Quote
Old 05-05-2003, 04:39 PM   #3
NWLee's Avatar
Two things to do to upgrade your exhaust; first port your manifold so the port on the engine matches the opening on the manifold, and second plug the hole on the bottom of the pipe with a screw and drill new hole on top for your pressure line, or else all the half burnt fuel/oil mixture will end up in your fuel tank. Tapping the hole is best but I just screwed the fitting in and it seems to work fine.
NWLee is offline   Reply With Quote
Old 05-05-2003, 08:17 PM   #4
so if i do this way, i won't loose any performance???
Old 05-05-2003, 10:18 PM   #5
NWLee's Avatar
I don't think performance suffers
Old 05-05-2003, 10:24 PM   #6
Korey Harbke's Avatar
Sounds like a good idea. I would try it. The nova rossi and RB piep are much better than the hpi composite pipe.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-06-2003, 04:44 AM   #7
spitfire's Avatar
Send a message via AIM to spitfire Send a message via Yahoo to spitfire
check out THS tuned pipe and header for the SS
around 50 bucks on Towerhobbies. good little pipe i hear
spitfire is offline   Reply With Quote
Old 05-06-2003, 08:37 AM   #8
i ended up getting Paris Racing Pipe. Hmm... hopefully, it'll work out well. do i need to change header along this pipe?? (sorry... i'm a newbie in nitro...)
Old 05-06-2003, 05:36 PM   #9
spitfire's Avatar
No you got the Tuned Header with your kit. that will work just fine
Old 05-09-2003, 10:51 AM   #10
unfortunately, my header got bent little bit. so the fuel leaks from the engine. most likely engine seems fine. but couldn't run it again due to bad glow plugs. is the THS pipe set compatible with .12SS engine??? also in general, RTR3 exhaust is compatable with SS exhaust??
what about RD Logics pipe set??? turbo OR not turbo?? i want more torque for better starting acceleration.
Old 05-09-2003, 03:37 PM   #11
spitfire's Avatar
yes the RTR is compatible with the SS. For better starts get the Racing clutch to engage at a higher RPM
GRP Tuned .21 Engine w/2053 Tuned Pipe (Turbo Plug) Poor Boy Racing R/C Items: For Sale/Trade 12 08-03-2011 09:46 AM
Difference between Novarossi 51603 tuned pipe and Novarossi RB x12 tuned pipe? racer rich Nitro On-Road 8 11-06-2010 07:52 PM
WTB:1/8 Tuned Pipe crazy4wdracer R/C Items: Wanted to Buy 6 06-29-2008 04:23 PM
AE NTC tuned pipe FS/FT rossoh10 R/C Items: For Sale/Trade 8 09-30-2006 04:13 PM
RB Tuned Pipe zimzum R/C Items: For Sale/Trade 0 07-23-2006 05:10 AM
