Old 08-09-2007, 11:03 PM   #1
rcaddict13's Avatar
Trader Rating: 67 (100%+)
Default jaco foams
anybody have any problems with the outside edge of the tires coming unglued,witch causes the tire to chunk on the outside. At first i thought it was just a one time thing but it happened every time i put a new set on and they all did the same thing. I was running the new jaco's 40 shore.Anyone else have this problem !
Xray t4 17 >< top sabre s4 >< ripon r/c raceway >< Gensace >< R1 wurks >< Protoform >< Motiv >< Gravity R/C >< Sanwa m12
rcaddict13 is offline   Reply With Quote
Old 08-10-2007, 12:21 AM   #2
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
sounds more like a setup issue than the tire. When running full size or larger tires, you have more "side bite" from the tire, causing the tire to be rolled(flex) under. When you have this "flex" of the tire, it is chunking. If you go to a harder tire, or add a little more camber, your tires will last longer without the issue you described.
rcfoolz is offline   Reply With Quote
Old 08-10-2007, 05:28 AM   #3
wallyedmonds's Avatar
iv found when i run them they do tend to come unglued so what i do now is after i true to size i just put a bead of glue around and its fine.
and just like elc carpet racing the bead around helps with the tire not folding under.
wallyedmonds is offline   Reply With Quote
Old 08-10-2007, 05:51 AM   #4
tancp81's Avatar
im using jaco foam tires before...
yeah im facing same problem that time... (maybe coz i left it half years...)
tancp81 is offline   Reply With Quote
Old 08-10-2007, 05:58 AM   #5
tancp81's Avatar
if the case u mention , i am facing this problem too ,every run time,the foam touches with turn buckle (i using bend foam tire)...
any suggestion if my bend foam tires still new???
Old 08-10-2007, 08:07 AM   #6
rcaddict13's Avatar
even after a 5 min heat race i had a front tire come half way unglued on the outside edge.On that set-up i was running 2deg camber in frt and 3 deg in the rear.The front tires looked fine(i just looked at them cus i was worried about therear tires) and the rear tire were chunked on the outside.My son went out for the 2nd heat and his car was all over the place and that's when i checked the frt tires and seen they were unglued.They should'nt come unglued like that so i was wondering if their were more tires like this as it could be a manufacture defect ?
Old 08-10-2007, 08:44 AM   #7
I have had the tires come unglued as well.
SMOKESHOW86 is offline   Reply With Quote
Old 08-10-2007, 09:52 AM   #8
Team Kamikaze's Avatar
Never encountered that problem.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 08-10-2007, 10:01 AM   #9
On my last race I had that problem with me rear tires. They chunked pretty good. I had only ran them for two practice runs. I replaced them with another new set but trued to size and the chunking went away. Maybe the new tires are being rushed out and not properly QA'd.
I'll see how my next race goes.
SasonRC is offline   Reply With Quote
Old 08-10-2007, 10:55 AM   #10
GHETTOTEACHER's Avatar
I had that problem also. I just reglued the sidewalls and burned them up in the next qual. I switched to ATS for the rest of the quals and main. No problems. Jaco's are normally pretty good.. Somebody goofed on that batch.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 08-10-2007, 10:57 AM   #11
At my hometrack, Toledo, if you hit one of the metal "berms" you can chunk a tire that is on the large size (73mm to 74mm) but usually not a smaller tire (71mm to 72 mm). If nothing is hit I have never chunked a Jaco tire.
The only time I have had an issue with the unglueing issue is if I don't run enough camber, I think they edge load and that causes the tire to rip off on the outside. If there is tire material left on the rim they are not coming unglued they are tearing loose which is not at all the same.
Ted
Ted Flack is offline   Reply With Quote
Old 08-10-2007, 01:51 PM   #12
duneland's Avatar
I have never found that the brand of the tire has anything to do with chunking. You hit stuff, you are more likely to chunk a tire. Running larger size increases the risk.
As far as comming un-glued goes,, I have another brand that seems more likely to suffer that fate. Mostly the segments sepperating. My jaco tires seem to hold up very well.
duneland is offline   Reply With Quote
Old 08-10-2007, 05:10 PM   #13
your not going fast enough,may i interest you in a ninja motor
im just joking.
Old 08-10-2007, 05:25 PM   #14
Old 08-10-2007, 06:35 PM   #15
Originally Posted by wallyedmonds View Post
ill get one too just to try
and ppl wonder why i just paint all purple i go through so many bodys its nuts
i wish 200mm body's where the same $ as 1/12 body's that would be sweet.
You race demolition derby? or you like to smack the wall a lot.
** CHEAP ** Jaco Sedan Foams Jaco 1/12 Foams New in Package 20+ pairs rc36deuce R/C Items: For Sale/Trade 23 10-07-2008 06:47 PM
NEED FOAMS? Jaco 1/10 Sedan Foams for Sale.. Desolas R/C Items: For Sale/Trade 0 03-17-2008 09:47 PM
Jaco Foams? MrLosi Australian Racing 1 05-16-2005 07:40 PM
Jaco Foams Kennedy Electric On-Road 17 12-02-2004 05:11 PM
need jaco foams!! crACkeD ChaSsiS R/C Items: Wanted to Buy 5 08-12-2004 08:44 AM
