Old 08-10-2007, 06:38 PM   #16
Originally Posted by wallyedmonds View Post
your not going fast enough,may i interest you in a ninja motor
im just joking.
I gotta ninja, and I am not having that trouble.Wich tires are the "new" Jaco tires?I am running 42 rears 40 fronts, with the 0 offset rim.
WARDO is offline   Reply With Quote
Old 08-10-2007, 09:42 PM   #17
Send a message via AIM to Bobby Flack
I have never personally had this happen, or even seen this happen with the nitro shoes or any other Jaco tire. I can't believe I have never seen one of these "bad tires" because I have used a lot of tires this year and never had a problem. What size are you running the tires at? What kind of truer are you using? Is your truer bit wore out? I've had a bad bit mess some tires up before so thats always a possibility. I just have to believe something weird is going on for this to happen more then once.
Bobby Flack is offline   Reply With Quote
Old 08-10-2007, 09:48 PM   #18
wallyedmonds's Avatar
Originally Posted by Team Kamikaze View Post
You race demolition derby? or you like to smack the wall a lot.
no
and i start at 61mm rear and 59mm front.
wallyedmonds is offline   Reply With Quote
Old 08-11-2007, 05:28 AM   #19
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
Something else that I just thought off, could it be that you might be using a tire compound? It could be that the compound is attatching the glue. I had a set of 45's that I had for 2 years, put them in a plastic bag after putting some tire compund on them. Those are the only tires I had come unglued.
I've ran at least 100 boxes of tires this year already, and I have not had a tire come unglued. I've seen other brands do it. I even just tried to use a hobby knife and put the tire on the truer and cut off the foam, that isn't happening, but I did find that those knife blades can come out of the holder. Now I know why they always say "DON"T DO THIS AT HOME"
rcfoolz is offline   Reply With Quote
Old 08-11-2007, 06:50 AM   #20
s10dude's Avatar
i use alot of tire mostly Jaco's and K-Factory and have never had one or seen one do that...wow...
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 08-13-2007, 11:31 PM   #21
We warranty all our tires from coming unglued and I don't recall ever seeing one returned for that reason. Is it coming unglued or just chunking? Do you see the rim when you peel back the rubber? If so, I want the tire back to see. We will obviously replace them.
Our machines apply a solid "sheet" of CA glue to the wheels. As a result, it is close to impossible for that tire to come unglued. One thing you need to know is that if you file or sand the edge of the wheel too aggressively when truing, it will overheat the glue and break the bond around the edge of the tire about 1/16" deep. This is true for most tires, not just ours. However, with this said, I've never seen one come unglued halfway around. I won't say it is impossible since anything can happen when gluing a tire, but I would bet it is a very isolated incident as opposed to a mass QC failure. If you saw our process, I'm sure you would agree.
Jack Rimer is offline   Reply With Quote
Old 08-14-2007, 10:29 AM   #22
mtveten's Avatar
Trader Rating: 27 (100%+)
I have been using Nitro Shoes for 2 seasons now and can say they are the only realistically priced brand thats is durable with good performance.
I would suggest that you round the edges of your foams smooth to the rim removing any donut overhand, this will greatly improve their durability.
Also with your G4 run a minimum of 3deg rear and 1.5deg front camber, you dont want your tires coning outward.
Mark
mtveten is offline   Reply With Quote
Old 08-14-2007, 10:40 AM   #23
serpent's Avatar
Send a message via AIM to serpent
Default Mystery Tire Removal
I'm driving along top (3) pace 15/5:12 .....All of a sudden the tire comes off happened twice same place on the track ..Anybody have this problem..I'm driving A Snake 960
serpent is offline   Reply With Quote
Old 08-14-2007, 11:07 AM   #24
A JACO 1/8 tire?
Old 08-14-2007, 11:23 AM   #25
duneland's Avatar
Tire or wheel?
duneland is offline   Reply With Quote
Old 08-14-2007, 11:33 AM   #26
serpent's Avatar
Originally Posted by Jack Rimer View Post
A JACO 1/8 tire?
Yes Jaco 1/8th! Tire and Wheel!
Old 08-14-2007, 11:44 AM   #27
cdelong's Avatar
I'd check the springs on your wheel lever. The rims fit so tight that sometimes you have to push the lever over the outside of the wheel.
..... front tire right?
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 08-14-2007, 11:47 AM   #28
duneland's Avatar
So it had nothing to do with it being a Jaco! Just didn't get the wheel on all the way. Or hit something that moved the quick release at the wrong time.
Old 08-14-2007, 11:51 AM   #29
captian's Avatar
yes i had that happin but it is because the jaco rim fits so good that when you push them on that you have to make sure the wheel lock pop's up and fully up sometimes it will go to just the edge and stop.
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 08-14-2007, 11:53 AM   #30
Man, the internet can make you look really good or really bad very quickly. LOL.
** CHEAP ** Jaco Sedan Foams Jaco 1/12 Foams New in Package 20+ pairs rc36deuce R/C Items: For Sale/Trade 23 10-07-2008 06:47 PM
NEED FOAMS? Jaco 1/10 Sedan Foams for Sale.. Desolas R/C Items: For Sale/Trade 0 03-17-2008 09:47 PM
Jaco Foams? MrLosi Australian Racing 1 05-16-2005 07:40 PM
Jaco Foams Kennedy Electric On-Road 17 12-02-2004 05:11 PM
need jaco foams!! crACkeD ChaSsiS R/C Items: Wanted to Buy 5 08-12-2004 08:44 AM
