MRX-2 parts?
MRX-2 parts?
I'm having a heck of a time finding parts for this thing...I have checked around at several on-line shops, and found almost nothing available for it.
I'm wondering if any of the parts from the MRX-4 will interchange, such as: suspension arms, F. hub carriers/bearing blocks, belts...and anything else you might think of.
Any help will be much appreciated,
Search ebay for an used MRX2.... Belts and pulleys are the same as the MRX4 als also the dampers and I believe the steerblocks, I think the rear upright of the MRX3/4 can be fitted on the 2.
Otherwise try to get an used MRX4.....
Cool...thanks
I periodically check ebay...just did earlier today and all I found under "Mugen MRX-2" was some tires
Good to know that at least I can get pulleys and belts...and I will try the steering blocks on for size.
