Old 08-07-2007, 02:29 PM   #1
Leyler's Avatar
Send a message via MSN to Leyler
Default How do i get the primer out?
im tired of the lil B*s*a*d how do i get it off?
sig.
Wicked Racing!!!!! :O
http://rcgearing.com
Leyler is offline   Reply With Quote
Old 08-07-2007, 03:03 PM   #2
Derby Bros Racing's Avatar
There's usually a retaining plastic that hold the primer inside the tank. Using a needle nose or a small cutter (be creative), you want to cut the primer from the inside of the tank. If you can't do this due to the design of the tank, you may pry it off but be really careful and try not to crack the tank.
Once the primer is off, find a screw slightly larder than the hole from the primer and plug it in.
The primer is something that you will see with RTR cars but they are not really needed. All you need to do is cover the exhaust (use a rag if it's hot) and pull the pullstart (or bump with a starter box) to prime the motor.
Derby Bros Racing is offline   Reply With Quote
Old 08-07-2007, 03:08 PM   #3
Leyler's Avatar
thx for the help, its spraying nitro all over my ppoor car!
sig.
Old 08-07-2007, 03:10 PM   #4
Primers only work for a while and then they go bad and is usually the source of all kinds of tuning problems on RTR cars. Yes, take it off and at least it's one less thing you have to think about.
Looking for an RC Electric Car Primer GulfstreamIVCap Electric Off-Road 1 05-30-2006 08:05 PM
primer look tekone Painting, Designs, Graphics and Photography 3 05-27-2006 12:31 AM
NEW HPI NITRO FUEL TANK W/ PRIMER (75cc) AND TUNED PIPE (COMPOSITE NYLON) bst R/C Items: For Sale/Trade 0 07-26-2004 02:46 PM
how to prime w/o primer? maxboost Nitro On-Road 10 11-14-2002 12:38 AM
