Old 05-03-2003, 05:39 PM   #1
Default Which Glow Plug to Use for MR-12?
I need help in choosing a glow plug for my MR-12?
Which should I use for the following factors:
1). Running 20%, at temperature ranging 17-24 Celsius(62.5-75.2 Fahrenheit
2). Running 20%, at temperature ranging 25-32 Celsius(77-89.6)Fahrenheit
1). Running 15%, at temperature ranging 17-24 Celsius(62.5-75.2 Fahrenheit
2). Running 15%, at temperature ranging 25-32 Celsius(77-89.6)Fahrenheit
If people could suggest a Novarossi glow plug for each factor that would be great.
Sami
ttektek is offline   Reply With Quote
Old 05-03-2003, 05:46 PM   #2
RedScorp's Avatar
Send a message via ICQ to RedScorp Send a message via AIM to RedScorp Send a message via Yahoo to RedScorp
Default Re: Which Glow Plug to Use for MR-12?
Sami
Well I don't know much about Rossi plugs but MC59 plugs are a good plug for a wide temp. range.
RedScorp is offline   Reply With Quote
Old 05-03-2003, 10:06 PM   #3
Korey Harbke's Avatar
Novarossi no. 5 should work good with the type of fuels your are using. Mcoy mc59 work good too.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-03-2003, 10:25 PM   #4
PG
I tried a #6 (average) turbo plug with 30% nitro (Trinity Horsepower Fuel) with MR 12 Turbo, runs hot but cooler than #5 (hot), the engine makes a crackling noise while on idle, I might switch to a #7 (cold) just to be on the safe side, that noise could be detonation. God these turbo plugs are expensive!!!
PG is offline   Reply With Quote
Old 05-04-2003, 12:12 AM   #5
My MR-12 has standard plugs.
-Sushi Boy
Old 05-04-2003, 12:52 AM   #6
Im2lazy's Avatar
i've used the stock plug and an OS 8 plug, both great. Absolutely no problem with either,so I would say from my experience OS 8 is a good bet (because you have low odds if your betting on getting the stock novarossi plug ). Mc 59's are very similar to OS 8's, but they are slightly more prone to deforming under heat and pressure so that the coil is a little bit more in the body of the plug then when it came from the factory. Even though, it is still a good plug, especially for the price.
Im2lazy is offline   Reply With Quote
Old 05-04-2003, 09:00 AM   #7
I would say a good hot plug such as the MC 59. The OS #8 is a good plug but the MC59 would be a better choise if you are running low nitro (15%)
nitro dipstick is offline   Reply With Quote
WHAT GLOW PLUG SHOULD I PUT IN IT............. kyosho 444 Onroad Nitro Engine Zone 1 04-14-2007 11:35 PM
glow plug help timmy187 Monster Trucks 3 04-19-2006 08:56 PM
GLOW PLUG FOR RB S5 HELLOkitty Electric Off-Road 4 10-24-2005 10:46 AM
RB S7 Glow Plug? RCWannabe Onroad Nitro Engine Zone 1 03-23-2005 09:09 PM
Glow Plug. tkhoo Nitro On-Road 7 07-14-2003 08:26 PM
