Old 08-01-2007, 04:13 PM   #1
bozla's Avatar
Default How to tell if an engine needs a new piston and sleeve.
I've got an engine thats had moderate use over the past 9 months. I think it might be due, but what are the tell tale signs?
bozla is offline   Reply With Quote
Old 08-01-2007, 04:40 PM   #2
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
if you can turn the flywheel with easy? "you might need a piston and sleeve"
if your engine lacks horepower? "you might need a piston and sleeve"
if your engine leans it self out? "you might need a piston and sleeve"
if your engine has over heated one time too many? "you might need a piston and sleeve"
if your engine doesnt seem to hold it carburator settings? "you might need a piston and sleeve"
Old 08-01-2007, 04:53 PM   #3
wallyedmonds's Avatar
after warm up it has bad idling
flames out easy
cant get a good tune
the signs of a air leak but you dont have one.
wallyedmonds is offline   Reply With Quote
Old 08-01-2007, 05:32 PM   #4
GHETTOTEACHER's Avatar
Don't forget these..
If you can turn the crank/fly wheel with two fingers with fuel in the engine..
If you don't feel any compression when turing the flywheel/crank and covering the carb....
If your car dosen't go faster nomatter how lean you turn the hsn.....
If your friends are blowing you away then later come and look at you car..Then say"It looks ok, nothing wrong".......
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 08-01-2007, 06:14 PM   #5
quietstorm76's Avatar
Listen to the exhaust port as you turn the engine over. If you hear lot of hissing the p/s is longer sealing up. No compression=No power. And the slowest guy at the track just lapped you.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-01-2007, 06:17 PM   #6
P2gee's Avatar
If you remove the piston and sleeve from the engine, and it comes out in more than two pieces.........time to re-up
Airtronics M-12
BYRONS Gen2 fuel
Capricorn C802
www.motorists.org
P2gee is offline   Reply With Quote
Old 08-01-2007, 06:32 PM   #7
charlesd's Avatar
When your engine looks like this:
charlesd is offline   Reply With Quote
Old 08-01-2007, 09:05 PM   #8
hey i do that kind of stuff.
Old 08-02-2007, 06:28 AM   #9
bozla's Avatar
Thanks guys, I have to check the compression and try a new plug first, but then its a new PS
Old 08-03-2007, 07:05 AM   #10
Wild Tiger's Avatar
Wild Tiger is offline   Reply With Quote
Old 08-03-2007, 07:38 AM   #11
teamgp's Avatar
Try a hotter plug as well to see if the power picks up and/or the idle gets better (i.e. lower number like a 6).
BTW, what motor is it? Has it been modified? What are the weather conditions you normally race in?
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 08-03-2007, 11:00 AM   #12
bozla's Avatar
Its a standard GS15R from kyosho with no mods. It seems that the compression is fine, maybe the plug was just shot. I didn't have a spare with me at the track, but someone lent me one - but I think that plug was dead too.
I just got some more plugs, an OS A3 and A5. Maybe the carb needs a clean too.
Old 08-03-2007, 04:54 PM   #13
ShrekNZ's Avatar
Remove the piston and sleve check the piston for scuff marks and if the piston will go all the way to the top of the sleve (and maybe out a little) it needs replacing. By the way check your crank bearngs as well if they are sloppy or crunchy they will need replacing and will affect performance and tuning - Atlhough it sounds like you may have found your problem anyway.
ShrekNZ is offline   Reply With Quote
Old 08-06-2007, 07:15 PM   #14
Trader Rating: 15 (100%+)
You might want to put a new rod in also on that one!
THE DOCTOR is offline   Reply With Quote
Old 08-06-2007, 08:15 PM   #15
mcsquish's Avatar
A little super glue and JB weld, no problems
mcsquish is offline   Reply With Quote
Like NEW LRP.28 Truggy Engine w/spare piston/sleeve/conrod MetalShield R/C Items: For Sale/Trade 2 06-15-2008 06:07 PM
12 engine help please piston and sleeve!? TurboLancer Nitro On-Road 2 11-22-2004 05:00 PM
Art. 08605 Novarossi Piston and sleeve is for which engine? esham Nitro On-Road 2 05-14-2004 01:59 AM
Piston/ Sleeve Pleskit Onroad Nitro Engine Zone 6 05-03-2004 11:57 AM
mugen mt.12 engine sleeve/piston still in pack nitro kid R/C Items: For Sale/Trade 0 01-09-2004 01:39 PM
