Bearing maintenance
Bearing maintenance
I have purchased a set of Acer bearings to use in my MTX4. I am interested in how often people maintain or replace their bearings, stock bearings or original.
With bearings like the Acer bearings I have found that cleaning them is of little use unless they have gone gritty as sometimes the shields do not replace sometimes correctly.
How long before you would feel a performance loss on bearings such as the Acer bearings?
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
that junkbox Mugen will be in the garbage long before those bearings.......(the r40,of course,would outlast those beaings......).....
Hi Buddy!!!!!!!!!
When I had the MTX4 and put the ACER bearings in it, I cleaned the bearings after every 2 racing days, unless the track conditions were dusty.
I'm still using the same original bearings from MTX3 and MTX4.
My recipe :
When the car is new, I put lots of tamiya ceramic grease inside all bearings.
Every 4 or 5 times worth of racing : I open the seal, soaked it in WD-40, spray with air or motor cleaner, put lots of tamiya ceramic grease in it, and put back the seals again.
Every 2 times of race meetings : I do the above cleaning process only for main shaft bearings ( the brake pulley ) and rear diff bearings.
After 2 years, my MTX3 get very few bearings replacement ( some bearings feel minor gritty or need new seals ).
i have been running ceramic since i got my first mtx 3.
all we have ever done is remove the seals, clean them with a air brush full of white spirits and we use to mix the smallest amount of white silicone grease in white spirits (30 to 1). which just leaves a fine amount of the white silicone grease which you can not even see.
you do this every race day if you want them to last.
now we use the acerracing bearing cleanner tool and oil.
dont pack them with grease this makes them go slow.
ceramics are ment to be free so way would you pack them with grease.
are you coming up to the titles
i have worn out the acer bearings before the mtx 3 . i replace parts on the mtx3 but have you ever had a go at putting the balls back in the bearing
you guys are removing the seal on an acer nitride ceramic?
Pleas tell me how and how to replace
Heard its not good to put ceramics on the wheels but well worth it for the tranny and diffs.Is this true ???
Having used acer & other high priced bearings in the past I would recommend against them for use in nitro cars or on dusty race surfaces.
In my experience the best option is to use decent low cost metal shielded bearings like those from Yeah Racing(light oil for less drag) or Avid RC (grease pack for longer lifespan) and replace them as soon as they start to get gritty.
All the bearing cleaning processes described will only remove grit from the bearings preventing further damage but will do nothing to repair the damage already caused by the debris. Oil them when the dry out but proper cleaning takes too long and just isn't cost effective.
When brand new those expensive ceramics may be a bit better but after a few races they will be far worse then a $15 new set.
The best cleaning process I have found is to remove the seals (only if you can do so without damaging them), throw the bearings in an ultrasonic cleaner (the cheap integy one works fine) submerged in a cleaning solution like motor spray, nitro cleaner or even nitro fuel for 10-15min. Blow them out good, oil them up and let sit overnight before before reinstalling the seals putting them in your car.
mark
mark
I'm not sure of what you guys are doing to ceramic bearings...I've got a set of sealed ceramics from Boca in my r40,....the bearings have TWO seasons of hard racing on them.....I use a compressor to blow the car off,raced with boards and without,and the bearings are as good as the day I bought them.,...
at the HPI challnege in oct 06,I broke the pillow balls 4 times on the boards,the bearings were fine.......
It sounds like the tracks you see are much easier on bearings and possibly foams that what we have in WA.
Mark
I run Acer bearings in my 720 and never really have problems. After every two races I take the whole car apart and take all the seals off the bearings, spray them out with denatured alcohol, and I get the stubborn dirt out with a toothbrush. You may have to repeat the process a few times if the bearing is pretty dirty, but in the end it doesn't seem like the dirt damages them. The Acer seals are good...you don't have to worry about damaging them when taking them off and replacing them. And of course, to take the seals off just get an razor blade or something up under the seal and pop it off.
I run AVID bearings on my 720 and they are pretty good and last a long time. I know this thread is about bearing maintenance, but the Avid bearings are $1 each so I just throw it away when it gets gritty and that's how I do my maintenance .
