Old 07-21-2007, 12:09 PM   #1
Default Removing Stripped Screw?
I stripped the allen screws for the motor mount...I need to get them out...Any ideas?
coolguy5 is offline   Reply With Quote
Old 07-21-2007, 12:29 PM   #2
Taylorm's Avatar
............slot it with a dremel for removal with a flat blade screwdriver.....or remove the allen head completely with a dremel, remove engine then remove leftover shaft with vice grips...................
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 07-21-2007, 12:31 PM   #3
cdelong's Avatar
If you mean the top screws that hold the engine onto the engine mount....
Take the engine out of the car using the screws on the bottom of the chassis. Dremel a slot across the stripped hex head using a cutoff tool and back it out with a screwdriver.
If it is a screw on the bottom of the chassis you can dremel a slot in the screw, but you need to use a small cutoff wheel so you don't cut into the chassis.
Take your time and use a steady hand
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 07-21-2007, 02:03 PM   #4
Roger's Avatar
You can also drill through from the bottom depending on what the screw is attached to ( chassis, etc. ). Just use the right size drill bit to do it.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Removing stripped screws Colby Rookie Zone 6 02-07-2008 01:05 PM
Removing stripped screws? cannon_eer7 Singapore R/C Racers 4 10-24-2005 09:10 AM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
stripped screw ntc3freak Nitro On-Road 23 09-21-2004 05:35 AM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
