Old 07-25-2007, 04:53 PM   #31
technazi's Avatar
I understand the hassle of removing the module in order to fit it to a radio case. However, it's just a small inconvenience compared to the rewards.
As for the antenna in the back, it took me a little while to get used to it and not have to extend an antenna out of the top of the radio. However, now that I'm used to just turning on and driving, it's nice to not have anything flying in front of my face (like an antenna) that would distract me from my view of my car on the track!
So, on the one hand, you have an extra step in removing the module from the transmitter when putting it away in a case. On the other hand, you have one less step in extending the antenna. Hmm... seems like the negatives cancel each other out!
technazi is offline   Reply With Quote
Old 07-26-2007, 03:47 AM   #32
quietstorm76's Avatar
I still pull my antenna up just because I like the balance.
quietstorm76 is offline   Reply With Quote
Old 07-28-2007, 06:53 PM   #33
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Where else can I get this? I havent been able to log on RC-Mushroom in a while...
Riketsu is offline   Reply With Quote
Old 08-01-2007, 11:28 AM   #34
alan1467's Avatar
Originally Posted by gansei View Post
i tested Sanwa Spektrum in last weekend..
i could feel it was more fast than Specktrum Pro.
so i could race more with good line.
i was very satisfied with Sanwa Specktrum..
But... Sanwa receiver Case(421) is too weak!!!
my Sanwa receiver Case(engaged teeth) was already broken by viration
you must reinforce receiver case when use sanwa spektrum.
Yes i'm very happy with mine but as you say the receivers are a little fragile. I have manged to break the lugs off one the hold it together by pulling out a tight servo plug when the receiver was servo taped in !!!!!
Any idea where to get a replacement case?
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 08-01-2007, 03:51 PM   #35
Bob Malphurs's Avatar
Might try the number below for parts. They ship quickly and prices are very reasonable.
Explain the problem and they may send one for free!
Global Services
Attn: Airtronics
18480 Bandilier Circle
Fountain Valley, CA 92708
TEL: 1-714-963-0329
FAX: 1-714-964-6236
Bob Malphurs is offline   Reply With Quote
Old 08-02-2007, 07:18 AM   #36
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Did we ever get a determiation if we can do the "antenna relocate" with this new system?
Ed Anderson is offline   Reply With Quote
Old 08-02-2007, 09:59 PM   #37
technazi's Avatar
What are you trying to "relocate"? The wire for the 2.4 antenna? That's going to be a little hard as the wire plugs into a small clip on the pc board. Not really sure if the circuit goes to another part of the board though.
Old 08-02-2007, 11:13 PM   #38
Wondering if we can relocate the antenna like we do with the Spektrum. I don't want the antenna hanging out the side.
Old 08-03-2007, 01:32 AM   #39
razzor's Avatar
Anyone know if this system is software based like the Nomadio and if you can use spektrum recievers.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-03-2007, 01:38 AM   #40
alan1467's Avatar
Not sure on the software bit but it will not work with Spektrum receivers
Alan
Tamiya TRF - Tekin
Old 08-04-2007, 05:22 AM   #41
Riketsu's Avatar
From where are you guys purchasing this???
Old 08-05-2007, 08:03 PM   #42
technazi's Avatar
Ed-
You might be able to move the antenna over. I can't recall how much antenna is really inside the case, but you might have enough to move it around for where you want to mount it. However, be advised that it will void the warranty.
Old 08-05-2007, 10:21 PM   #43
choisan's Avatar
Compared with the Spektrum Pro, is the Sanwa faster, response wise. Pls kindly advise!
choisan is offline   Reply With Quote
Old 08-12-2007, 10:55 AM   #44
alan1467's Avatar
Default Case Breaking
Anyone else find the reciever case is very fragile? I broke 2 today. The bottom part just appears to break the lugs off and the case falls apart. But I have a freind with the same reciever in 40Mhz an he has had no problem. So is it just the 2.4Ghz ones? And it appears you can not buy new cases
Tamiya TRF - Tekin
Old 08-15-2007, 08:48 AM   #45
gansei's Avatar
i got some glitch after changing sanwa specktrum.
the glitch was happened only throttle servo.
and the glitch is not happen frequently... about one time per 2 days run?
the glitch like this:
open throttle in transmitter -> did not open
close throttle in transmitter -> did not close.
so i changed throttle servo.. if throttle servo was badness..
But.. the throttle glitch was also happened..
my car is G4S... and my friends(who drive NT1 and sanwa Spektrum)
experienced the same throttle glitch..
anyone who experienced same case?
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Spectrum Pro for Airtronics M11 Roger R/C Items: For Sale/Trade 6 06-27-2008 11:34 PM
WTT/ WTS Airtronics M11 w/ spectrum pro Hrdluck13 R/C Items: For Sale/Trade 21 07-13-2007 10:11 AM
AIRTRONICS M11 w/SPECTRUM PRO 27.045 mlt138 R/C Items: For Sale/Trade 15 12-28-2006 12:25 AM
AIRTRONICS M11 W/SPECTRUM AND 2 SPECTRUM RECEIVERS burm R/C Items: For Sale/Trade 10 03-05-2006 01:28 PM
NIB Spectrum for Airtronics M8 BSchorr R/C Items: For Sale/Trade 12 06-22-2005 08:19 PM
