Old 07-22-2007, 10:41 AM   #16
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
HERE IS THE LINK FOR THE MOD
http://xtremerc.com/pages/howto.php?howto=16&page=1
entitymugenmtx is offline   Reply With Quote
Old 07-23-2007, 10:19 AM   #17
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
I have a few questions like:
How much is the extra receiver?? And where can I get it?
Where have you guys found the cheapest online shop to buy this module/receiver??
Has anyone tested this against the Pro System? Is it that much faster?
Is it protected against water and fuel like the Pro System claims??
(Thank god they were only "few" right? LOL) Sorry for all those questions, I have a M11 sitting here without module and I need to go out and buy either this or the spektrum pro...
Riketsu is offline   Reply With Quote
Old 07-23-2007, 10:44 AM   #18
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
I believe the frame rate (if that's the terminology, and correct me if I'm wrong) is faster than the pro system. I heard the Spektrum is at 50hz, and Airtronics' spread spectrum is at 100hz.
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 07-23-2007, 10:52 AM   #19
RevMaxx's Avatar
Send a message via MSN to RevMaxx
this is +1 for Airtronics 2.4GHz....
hopefully gansei comes back and share to us his 'hands-on' comparison between spectrum pro and airtronics'
RevMaxx is offline   Reply With Quote
Old 07-23-2007, 11:14 AM   #20
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Spektrum compatiblity
Is this system compatible with Spektrum receivers? Or do we have to start the buying process all over again?
Ed Anderson is offline   Reply With Quote
Old 07-23-2007, 11:16 AM   #21
Originally Posted by entitymugenmtx View Post
Have you had your Airtronics one apart yet? Will this mod work?
Old 07-23-2007, 01:16 PM   #22
gansei's Avatar
i tested Sanwa Spektrum in last weekend..
i could feel it was more fast than Specktrum Pro.
so i could race more with good line.
i was very satisfied with Sanwa Specktrum..
But... Sanwa receiver Case(421) is too weak!!!
my Sanwa receiver Case(engaged teeth) was already broken by viration
you must reinforce receiver case when use sanwa spektrum.
MY SPONSORS:
★ Show Hobby(Novarossi)
Km Racing HK1 Meen Version
Another Nick: Bander
gansei is offline   Reply With Quote
Old 07-23-2007, 01:16 PM   #23
gansei's Avatar
Is this system compatible with Spektrum receivers? => NEVER!!!
Or do we have to start the buying process all over again? => YES!!
MY SPONSORS:
Old 07-23-2007, 04:57 PM   #24
MY FRIEND HAS THE M11 WITH THE MOD AND IT WORKS JUST FINE
Old 07-23-2007, 07:21 PM   #25
Not the Spektrum, but the Airtronics? Can you get any pictures?
Old 07-24-2007, 02:23 AM   #26
Arno's Avatar
If you go down to post #9 there are pictures sanwa and airtronics Spectrum are the same and they look the same the only difference are the stickers on them one says Sanwa and the other Airtronics.
Arno is offline   Reply With Quote
Old 07-24-2007, 08:01 AM   #27
My "Spektrum" dosen't look anything like that! It looks more like the one in the link posted on post #16. The antenna is on the left instead of the right. But the wire attaches on the right side of the board, giving you slack and the ability to move the antenna.
This Airtronics "Spectrum" has the antenna on the right. Is it connected "hard to the board"? Is there enough slack in the wire to move the antenna??
Mine also doesn't have a Sanwa or an Airtronics sticker on it.....It has a Spektrum sticker on it.
Old 07-24-2007, 01:18 PM   #28
Arno's Avatar
Yeah then yours is the one made by spektrum not by Sanwa aka Airtronics. I have not seen the inside of the Sanwa aka Airtronics so I couldnt tell you if it is connected hard or with a snap on little plug like the Spektrum, maybe some one else that has opened it before can jump in and help you with that.
Old 07-24-2007, 08:32 PM   #29
technazi's Avatar
Internally, the DSS module's antenna does basically 'snap' in to the board like the Spektrum system. However, you can rotate the antenna on module about 270 degrees around so there's no need to move anything to one side or the other. If you don't like the look of the small antenna sticking up then simply lay it on its side.
As for modding the spectrum's antenna to run it up to the main antenna of the M11 or M8, there's absolutely no need for it. The output is only 10 milliwatt on the DSS system, but that's plenty of power to transmit where you don't need any more power. You won't be able to tell which way your car is going by the time it gets out of range.
technazi is offline   Reply With Quote
Old 07-25-2007, 10:57 AM   #30
Bob Malphurs's Avatar
I don't think anyone wants a performance gain with this mod! Looks and convenience is more the issue. The antenna sticking out the back is awkward to say the least. On my M8 with the spectrum module I have to remove the module to get it to fix my TX case.
Bob Malphurs is offline   Reply With Quote
Spectrum Pro for Airtronics M11 Roger R/C Items: For Sale/Trade 6 06-27-2008 11:34 PM
WTT/ WTS Airtronics M11 w/ spectrum pro Hrdluck13 R/C Items: For Sale/Trade 21 07-13-2007 10:11 AM
AIRTRONICS M11 w/SPECTRUM PRO 27.045 mlt138 R/C Items: For Sale/Trade 15 12-28-2006 12:25 AM
AIRTRONICS M11 W/SPECTRUM AND 2 SPECTRUM RECEIVERS burm R/C Items: For Sale/Trade 10 03-05-2006 01:28 PM
NIB Spectrum for Airtronics M8 BSchorr R/C Items: For Sale/Trade 12 06-22-2005 08:19 PM
