Old 07-17-2007, 11:11 AM   #1
Corse-R's Avatar
Default Tyre truers: Carbide cutter or sawtooth?
The title says it all... some time ago my Atlas tyre truer died and changed them for a Hudy unit, now the sawtooth bit that came with it has worn and I'm looking for a replacement.
My question is: Who prefeers the sawtooth and who prefeers the carbide bit and the most important... why? Let's hear your opinions.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 07-17-2007, 11:22 AM   #2
Trader Rating: 14 (100%+)
I have used both and I perfer the Hudy carbide cutter. The surface I got after cutting was pretty wavy/wrinkly. It would take a couple laps to "break in" the tire. The cut was made on a Integy truer that I was able to use from a fellow racer. When I bought my Hudy truer, it came with the carbide cutter. It gave a much better finish, pretty much the same finish as the tire came out of the box. There is still a "break in" period with the tires but not as long as the hacksaw blade cutter. I experienced this first hand at the Byron race. Fresh tires and the car handled like crap, after a lap or two, the car was hooked up. Im pretty sure this was due to freshly cut tires and not due to tire diameter wear (MTX4). Ive also seen some guys take the sandpaper/sanding stick they use to round the tire edges run it across the tire to "break it in".
thunderbt3 is offline   Reply With Quote
Old 07-17-2007, 11:29 AM   #3
YBSLOW's Avatar
Carbide gives a much smoother cut. Worth the extra money especially if you all ready bought the Hudy truer.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 07-17-2007, 07:19 PM   #4
I found that the sawtooth bit didn't last very long, over time the cut just got worse and worse. After switching to the carbide, I noticed a smoother cut, and much less tire smoke. it did start to wear out after 2 years, so I switched the bit around in it's holder, and just as a knife's blade curls over to one side, the same thing seemed to happen to the bit. after flipping it round, it cuts like new, and hopefully will last until my clumsy self drops the truer and shatters the plastic cover
KamikazeRCRacing.com
jamezracer is offline   Reply With Quote
Old 07-17-2007, 07:46 PM   #5
JMGarrett's Avatar
Send a message via Yahoo to JMGarrett
Default cutter
Hudy use to make a diamond cutter bit for a tire truer if you cn find one (good luck) it is the best i have one that i bought from a retiring racer and it is so much better than tha carbide tip, i can take off 4mm a pass with a smooth cut.
JMGarrett is offline   Reply With Quote
Old 07-17-2007, 07:48 PM   #6
TC_Tuner's Avatar
Trader Rating: 34 (100%+)
Default carbide cutter
anyone know a good spot to buy one online or ebay sellers?
Airtronics | Byron's Fuel | Pro-Line | OS | Kyosho | Ballistic Batteries | RIP Al's Hobby Shop
MRX4-X F180 Cobra Zipper Kart Yokomo BD Cup Racer FM1e Recoil M18 Pro Scalpel dNaNo Baja 5T HB D8 Vorza ERevo Savage Flux SCX10 GT2 T4 Slash Ten SCTE Blitz ESE HB Cyclone D4 Mini ERevo Vendetta ST Mini T Micro T
TC_Tuner is offline   Reply With Quote
Old 07-18-2007, 04:55 PM   #7
kcrunchone's Avatar
If you are going to use the saw blade you must pick up a good one get a makita, bosh, porter cable. They will do a better job and last much much longer. Like stated I also prefer the Hudy bit but I still keep the Bosch blade in my tools just in case something went wrong with my hudy bit....
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 07-18-2007, 06:21 PM   #8
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
anyone have any pics of these blades?
I don't use a truer yet and am having a hard time vizualizing what everyone is talking about.
regg151 is offline   Reply With Quote
Old 07-18-2007, 06:49 PM   #9
kcrunchone's Avatar
Regg they are jigsaw blades...
http://www.westerntool.com/content/w...S/BOS_T500.jpg
Rick Hill
Old 07-18-2007, 07:28 PM   #10
regg151's Avatar
ahh ok here I was thinking they were some sort of specialized blades I have a bunch of them laying around the shop.
now all I need is a truer to go with them
Old 07-20-2007, 09:07 AM   #11
ALG
Guys, when you get the saw blades, you can have them with diferent "Tooth per inch" This is the separation between the tooth. the more separated "18T per inch" (for wood or Alumiminum) your cut will have more grooves and with a "24T per inch" (Steel or hard Steel) you can get a smoother surface.
Remember to cut the tires slow!!
ALG is offline   Reply With Quote
Old 07-20-2007, 11:55 AM   #12
lil-bump's Avatar
Trader Rating: 83 (100%+)
I normally go with the 24 tpi Bosch
lil-bump is online now   Reply With Quote
Old 07-20-2007, 02:27 PM   #13
wallyedmonds's Avatar
i like saw blades
had a hudy one and sold it
wallyedmonds is offline   Reply With Quote
Old 07-20-2007, 05:00 PM   #14
Bob Malphurs's Avatar
When I bought my 3Racing Tire Truer, it came with the saw blade bit. In fact it had 2 pieces of hacksaw blade (approx 3/4th inch long) sandwiched together! The blades looked like 18-tooth and the points were staggered.
Actually cut very well with little or no smoke, and was able to cut several mm at a single pass. The cut surface was very smooth. I've since gone to the Hudy carbide; I know that it'll stay sharp a lot longer!
Only problem I had with the Hudy was the depth of the cutter was less so the calibration mark was off by +5mm. A little cut mark with a dremel and a dab of white paint and I was good to go!
Bob Malphurs is offline   Reply With Quote
Old 07-20-2007, 05:03 PM   #15
One thing to note with saw blades is the direction of the teeth. They should point in the direction of the first pass.
carbide cutter (tire truer) impdog Electric On-Road 4 08-03-2008 07:56 AM
WTD - Hudy Carbide Cutter CDS70 Australia Wanted to Buy 0 03-26-2008 02:45 AM
Hudy arbors an carbide cutter samstheman2 R/C Items: For Sale/Trade 17 11-23-2007 11:45 PM
MAX MOD CARBIDE CUTTER gezer2u R/C Items: For Sale/Trade 2 02-15-2007 05:49 PM
carbide cutter for tire truers (brand new) dakrat R/C Items: For Sale/Trade 4 04-19-2006 07:04 PM
